POssible Engine Swaps
Old May 23, 2006 | 02:44 AM
  #81
hotbox05's Avatar
Originally Posted by BUCKO
I think the 2ZZ-GE (180hp stock) is the way to go... figure it'll cost $2,500 to buy + labor... a SC kit cost $3,200-$4,000 and may not give you that 75hp+ gain. I'm speaking to a guy about it, who does a lot of swaps and toyota engine build ups. As for having to worry about being pulled over for an soup'd car, i recomend buying a folder and putting the CARB certs from all the product you have on your vehicle so if you get pulled over, you have legit proof that your car is street legal. Know your rights, you can only get ticketed if your vehicle is out of noise ordinance (sound system or exhaust system) 30dbs from 100' i think. or if you have illegal products on your vehicle like Nitros Oxide. Also include the federal act that protects consumers and aftermarket companies in your folder.
the 1zz when trd supercharged has the same power but much more torque and no worries about bending valves.....
the trd kit is 1920.00 when you know how and where to look.
problem is the majority of simple stuff do not have carb certs......
and i dunno what state has a 100 foot 30db law but it sure isnt california.
Old May 23, 2006 | 06:22 PM
  #82
sikbrik's Avatar
Okay, so the 1zz and 2zz blocks are pretty much the same length (even though different materials) but the overall length with head/accessories seems somewhat different. Anyone with any length specs at all? Thanks.
Old May 23, 2006 | 06:28 PM
  #83
CHPRBOX8's Avatar
in the new scion books at the dealerships their is a xb that has 400hp that did an engien swap they put a toyota 22 rt motor in it
  #84
CHPRBOX8's Avatar
Old May 23, 2006 | 06:59 PM
  #85
RTon20s's Avatar
Much more than an engine swap. It has been discussed in the forums several times. That xB was actually mounted on an older Toyota pickup frame allowing the owner to very easily run the 22rt.
Old May 23, 2006 | 07:32 PM
  #86
hotbox05's Avatar
my sister has a 2005 corolla so i can check the 1zz length.if i remember correctly from a few months ago when i measured a matyrix the 1zz is about 1 inch longer.
Old May 23, 2006 | 08:08 PM
  #87
sikbrik's Avatar
That would be great info to confirm. Thanks, HotBox!
Old May 29, 2006 | 04:02 PM
  #88
Jhhnn's Avatar
From sikbrik-
"How much of an overbore, and how much power do you really think that would give you? You'd need a 3mm overbore to get you to a 1.6 liter. That's huge in the engine world. Are the bore centers even spaced far enough apart to sleeve with a 78mm bore?"
As you say, it really depends on the bore center dimension, and I don't know what's there. If the motor could be punched out w/ sleeving to get 1800-1900 cc's, it'd probably be worth the trouble. Only an engine shop that specializes in that kind of work would have the answers...
I've seen a variety of engine swaps turn into complete clusterflucks over the years- even ones that appeared easy often have undesirable side effects. Swapping out aluminum block motors for cast iron can badly compromise handling, for example, even if it's a relatively straightforward bolt-in operation...
So, be careful what you wish for- you just might get it, and it probably won't be what you thought it would be...
Old May 30, 2006 | 05:27 PM
  #89
sikbrik's Avatar
the 1zz is also an alloy block but all signs point to it being too long to fit without cutting the chassis. Not my cup of tea.
Old Jun 7, 2006 | 12:42 AM
  #90
trixspeed's Avatar
I remember an issue from Import Tuner early last year that featured an XA that was boosted and stroked to 1.7 liters putting down 217 HP. So that does prove stroking the engine is the best option.
Old Jun 7, 2006 | 03:34 AM
  #91
hotbox05's Avatar
that article was a lie and that is the now 4efte motorswapped car.
Old Jun 7, 2006 | 03:38 PM
  #92
sikbrik's Avatar
Aside from that, it doesn't really prove anything until you also prove that someone can't make 217hp on an unstroked, or even destroked, 1nz.
Old Jun 7, 2006 | 08:15 PM
  #93
hotbox05's Avatar
1nz is not a stong building powerplant.
Old Jun 7, 2006 | 09:56 PM
  #94
sikbrik's Avatar
I tend to agree with hotbox, so that would also apply to any 1.7 liter "stroker" 1nz as well. Not worth the time/effort/expense unless you've got connections to a machine shop or too much money/curiosity to keep you grounded.
Overall, it seems that the best you can do with these cars (reliably) is some mild forced induction and maybe a few little efficiency tricks here and there and hope for 160-180hp max.
...is anyone even considering a 1zz? I've been comparing pics I find online but don't have access to a 1zz block to take measurements. Mounting looks nearly identical , although I'm sure the front mount is offset somewhat differently. Overall length would still be my biggest (and really my only) concern. Overall width doesn't appear to be that much different, especially on the newer engines with the similar composite intake, etc.
With a slightly modified NA 1zz, you'd be looking at that same 160-180hp you would have got from the boosted 1nz. Maybe more money, maybe the same, maybe less. It opens up the door for bigger and better things, though.
Did I read somewhere that the 2zz fit that car (you know, the echo hatch or whatever it was...) lengthwise but the overall width was the problem? Or did they have to channel the 'frame' somewhat to accomodate the length?
Old Jun 7, 2006 | 11:44 PM
  #95
hotbox05's Avatar
2zz and 1zz are the same size so it should fit the same. and i believe on the vitz that has the 2zz they modified the firewall and notched part of the subframe.
Old Jun 8, 2006 | 08:50 AM
  #96
ae86kid87's Avatar
cool
JonathonK
Mar 22, 2018 09:00 AM
VitaminE
Mar 24, 2015 03:36 PM
churrosurf
Jan 30, 2015 01:12 PM
trickedxb
9
Jan 16, 2004 07:34 PM
Torokun
21
Sep 25, 2003 03:02 PM
