Problems with the Perrin Pulley
Old Nov 2, 2004 | 02:19 AM
  #41
TOAST3R's Avatar
Originally Posted by squirrel
It looks like someone didn't read the drawing/blueprint corectly.
As soon as Munch gets the proper pulley installed, I'll order it.
ya thats what im thinking, mistakes like this do happen. look at nasa, they crashed a super expensive space thingy once because one team worked in metric and the other worked in inches or whatever
Old Nov 2, 2004 | 02:34 AM
  #42
Dewmerz's Avatar
You just can't stop modding so us newcomers can catch up....
Old Nov 2, 2004 | 02:40 AM
  #43
squirrel's Avatar
While my 2 year old son was napping, I installed the TRD shift light kit in less than an hour! :twisted: :twisted: :twisted:
I waiting for some hardware to show, so I can do another mod before the week is out.
I have a few other items of interest, but I need the strength in my right hand to come back first.
Old Nov 2, 2004 | 03:02 AM
  #44
scionmag's Avatar
hate to sound like a mechanical idiot... but can these pulleys be used on automatics also?
Old Nov 2, 2004 | 04:55 AM
  #45
Guest
Guest
Posts: n/a
And as squirrel was moding, the scion central was open late burning the midnight oil as well, making some late night mods. :twisted: I am also waiting to see what the result is on the pulley mod. :D
Old Nov 2, 2004 | 11:21 AM
  #46
Munch's Avatar
Yes it can.
Old Nov 2, 2004 | 03:12 PM
  #47
the_saint's Avatar
Originally Posted by mgithens
where do you get the idea that a harmonic balancer that has been lightened by a machinist is any better than an aftermarket part...?? that doesn't even get close to a comprehension of what a harmonic balancer does... you first need to go take a course in engineering called Kinematics... but before that you'll need Dynamics, because you'll at least need a handle on the physics behind the purpose of a harmonic balancer... then you can move on to machine design...
then you can come back and edit your post to let people know that you have absolutely no idea about engine parts...
physics/kinematics lesson... inertia is the force that keeps the engine in motion, mass is part of the equation... if you took away this "balancing" that is provided on one end by the flywheel and on the other end by the harmonic balancer/pulley you would get an engine that would shake to pieces - due to the nature that the engine is only firing one cylinder every 180 degrees, so we offset this to give the engine longevity... without it we'd lose oil pressure in literally months - instead of years because the vibration would first cause the bearing seats to deform or wear abnormally - thus causing the clearnces between crank and block to become irregular and over spec... so an engine designer will take into account all the aspect of this engine - crank couterweight design, compression, horsepower, environmental factors, etc... these are things that you can only guess about, they will not give up this info... now they take this info to determine the amount of inertia that the engine can use, more is better for vibration control, but more inertial resistance means a slow revving engine - so a balance must be determined... by shaving weight off the flywheel and/or harmonic balancer you will absolutely deviate from the expected life of the engine, but you will see a quicker revving engine, so downshifts and upshifts will occur quicker BUT you will be hard pressed to measure an acceleration difference... you will gain a benefit from a smaller pulley because all the accessories will be getting less power and the drivetrain will get that power instead...
YOU WANNA SAVE INERTIAL LOAD?? take those stupid 19" or 22" rims off your car that wasn't designed for that... get lighter rims, but KEEP THE SAME DIAMETER... use low profile tires and you will see a regearing that will absolutely make a difference in how much torque you are putting to the ground... torque is what you are after in a sports car, horsepower allows for higher top end speed, it is a measure of work - which has no time limits... torque is where the acceleration is... so how is torque measure... ft-lbs... that means a force applied over a distance - or more accurately at a distance... so let's talk numbers... let's say you have an engine that makes 100ft-lb, then you are in 1st gear and your total drive ratio for 1st gear is about 14:1... then drivetrain eats some power (which becomes heat), so after the reduction of speed to 1/14th of the speed you would expect 14 times the torque, but you will see maybe 11 times due to the losses... so we now have 1100ft-lbs of torque coming through the driveshaft... so to determine how much "force" or "power" you are putting to the ground you have to divide your available torque by the radius of your tire... most tires are like 28" tall - give or take, but we'll just say 24" because 1/2 of that (the radius) is 12"... 1 foot... so now we have 1100 lbs of force accelerating the car... ok... so let's look at a larger rim and tire combination... let's exagerate... go to 36"... half of that is 1.5 feet... so now we have to divide 1100 ft-lbs / 1.5 ft... so we get 733 lbs of "thrust"... so this is why your 4x4 truck is slower with the big wheels...
I'm rambling... but that is Capt Morgan talking... but the point is that this is information, not my opinion... I am backing what I say by the facts that have made me come to believe what I do... instead of just spewing useless opinions like so many in the message board realm do...
sorry for the flame, but I get so tired of people claiming to know something that they follow up with information that proves they don't...
Originally Posted by scionxb04
"where do you get the idea that a harmonic balancer that has been lightened by a machinist is any better than an aftermarket part...??"
because they can balance it after its been lightened and it still retains the harmonic dampener
the harmonic dampening isn't because the unit is balanced, it is because of it's mass... the more mass at a larger radius the better for dampening... the lighter the less useful it is...
I'm waiting for you to attempt to explain torsional resonance to these guys. Good luck!...
George
Ugh, my head hurts :?
Old Nov 2, 2004 | 07:02 PM
  #48
PERRIN_JEFF's Avatar
We goofed big time! Yes the pulley doens't fit, the inside pulley is a 10% reduction, which causes it to interfere with the oil pump housing.
We made 2 different pulleys as prototypes, one same size as stock, and one with a 10% reduction on the PS side of the pulley. During the test fitting, the stock one fit and the 10% reduced one didn't! When it came time to make the production part the program for the 10% reduction was used, not the stock size. That is also why on our site we don't mention anything about them being 10% reduced on the PS side, because its not supposed to be reduced.
Anyone that has one of these pulleys in hand needs to contact us so we can exchange them for the right pulley (which are going in production later today). You may also contact your dealer you bought it from to do the exchange. At this point it will be 2-3 weeks before we ship them out to the customers.
We are very sorry for the inconvenience we have caused to anyone that has installed this pulley. We are doing our best to quickly get the right parts made and out to the customers.
Munch thanks for bringing this to our attention, i am glad you are being very understandable about the situation.
The good thing about our goof is we now have some really cool, expensive paper weights for Christmas gifts!
Old Nov 2, 2004 | 07:10 PM
  #49
DJ_X_Trodinaire's Avatar
wow first time i saw a manufacturer admits to teh boo boo
I applaud you for your honesty
  #50
TOAST3R's Avatar
thanks for letting us know what happened and in a quick manner!
now i need to go call vividracing. ill post what their course of action is after i get off the phone
Old Nov 2, 2004 | 07:11 PM
  #51
eeyoredragon's Avatar
Frisbee's of Death!!! ;)
Old Nov 2, 2004 | 07:14 PM
  #52
Munch's Avatar
And the mystery is solved . Thanks for the phone calls I appreciate it. I just wanted to get this situation resolved and now it is.
Old Nov 2, 2004 | 07:15 PM
  #53
Munch's Avatar
It happens bro. I just wish I didn't have to find out first
Old Nov 2, 2004 | 07:16 PM
  #54
TOAST3R's Avatar
ok i just called vividracing, jon is sending me a return label to send it back and is ordering the correct one for me. if you got yours from vividracing also drop them a line
sales@vividracing.com
1.866.44.VIVID ext 290
AIM - vrgraphixxxs
www.vividracing.com
Old Nov 2, 2004 | 07:21 PM
  #55
Munch's Avatar
AIM - vrgraphixxxs
www.vividracing.com
I'm sending mine directly to Perrin. I already got an RMA number from Jeff. I guess I'll be the first one to get the correct pulley
Old Nov 2, 2004 | 07:23 PM
  #56
superjeer's Avatar
In my line of work it's a cliche to say "Every problem is realy an opportunity" I like to punch those people that say that in the mouth, but in this case it's true. I'll be getting the pully and shifter from Perrin because of this quick response and honesty.
Old Nov 2, 2004 | 07:40 PM
  #57
VividRacing's Avatar
We are sending return labels out to our customers, and having the new pulleys ship from perrin, once they are ready, thanks for you patince in this matter.
Jon.
Old Nov 2, 2004 | 08:08 PM
  #58
squirrel's Avatar
Alrighty now. Looks like I'll be contacting Vivid Racing soon so I can get a set of Perrin pulleys!
Old Nov 2, 2004 | 08:12 PM
  #59
Munch's Avatar
About 3 weeks till the right size pulley will be available
Old Nov 2, 2004 | 08:13 PM
  #60
the_saint's Avatar
Is it a set? I thought it was just the crank/balancer pulley.
