Question about Intake breather hose filter. Please Help
Old Apr 27, 2007 | 02:19 PM
leov36's Avatar
Default Question about Intake breather hose filter. Please Help
i just bought a injen short ram intake knock off. so everything looks good, im using a K&N filter instead of the supplied foam one. anyways, my question is, i was looking through the breather hose filter and noticed on one end i see white foam and the other end appears to have a black piece of plastic completey sealing up the inside. now this doesnt make sense to me because how could air be vented through there if its all sealed up, has anyone every looked through there little filter? should i drill out the black piece? please help.
Old Apr 27, 2007 | 04:57 PM
vintage42's Avatar
Default Re: Question about Intake breather hose filter. Please Help
Originally Posted by leov36
i just bought a injen short ram intake knock off.... i was looking through the breather hose filter and noticed on one end i see white foam and the other end appears to have a black piece of plastic completey sealing up the inside.... how could air be vented through there if its all sealed up,... should i drill out the black piece? ...
Could you be looking at a backflow flapper valve? I think breathers have valves to let crankcase overpressure pulses out, but not let air back in.
Old Apr 27, 2007 | 06:13 PM
leov36's Avatar
no i dont think so, i put a screw driver in there and i seems that one side is all sealed together, it doesent move as if it were a valve. i think im just gonna drill it out.
Old Apr 27, 2007 | 11:34 PM
jct's Avatar
jct
if you drill it out your gonna foul up your maf sensor
just a heads up...
Old Apr 27, 2007 | 11:46 PM
frogbox's Avatar
Have you checked it by blowing and sucking through it? If air flows one way but not the other, it has a flapper, if not then drill it.
I don't have one in mine, I have a K&N Typhoon and have had no problems with contaminated MAF. If it did get contaminated I would worry about too much blow-by and would need a new engine.
just test by blowing and sucking on it.
Old Apr 28, 2007 | 02:23 AM
D_M_A_N's Avatar
wow... somebody could really run with that comment ^^^
Old Apr 28, 2007 | 02:47 AM
leov36's Avatar
ok, so i tried to drill out the side that was occluded and i freekin went to crazy and drilled out some of the actuall filter element. now im screwed. any one know how i could find a new part? i emailed the place were i bought it from and also injen, to see if i could order one from them.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
