REALLY NEED HELP,,,my car won't go over 83mph ?????
Originally Posted by hotbox05
215/35/18 is stock diameter. or dang near it.
Yup. The calculator that I use (the one from 1010tire) shows it to be .55 inches bigger circumference and 6.6 revs per miles less. So, I would be going just a tad faster than my speedo says.
i take out for a test today and it seems like what Tomas was said, i drove at 55mph then turn OD off, the RPM start to jump up 1rpm more, when i turn on the OD again,,it drop back to the same RPM like before immediately... and also when i bought the car, the owner told me that it was stolen that why its has a salvage title,,,he has all the receive to show me that it was stolen... THANKS
Very possible. Salvaging a car when it's stolen is very common for vehicles that are nearly new.
It could be as simple as ONE WIRE either cut, broken, or not connected that would keep an electronically controlled transmission like ours from shifting into OD, but still have everything else working fine...
The thought of checking the accuracy of the speedo is an EXCELLENT idea - if anyone at any time removed the pointer from the speedo (and/or tach), it could very easily have been put back on slightly wrong (it a PITA to get right).
Tom
Tom
where can i buy the G.P.S? is that the easiest way to check my speed... my car only drive about 230miles max on a full tank of gas even after i upgrade everything for gas mileage. Do you guy know if there is a device that i can buy to check for the code and fix it myself if it's electrical problem. thanks
There are numerous ways to check for codes - one is to stop by an autoparts store - many will read the code for you for free, assuming there is one displayed. Another way is to grab something like the ScanGauge II that one of our sponsors has available at an excellent price for ScionLife members (search for ScanGauge).
A GPS isn't necessary, just easy. I have no GPS so I just pick a nice straight section of freeway, at night so I don't have to fight as much traffic, and run ten miles at as close to exactly 60 MPH as I can the whole way, using the freeway mile markers. That should take exactly ten minutes - if it doesn't you can figure out your true speed pretty easily (36000 divided by how many seconds it took to go ten miles equals MPH - 36000/570=63.16MPH, for example). If you trust the mile markers are accurate, doing it for just a mile is quicker and easier (3600/seconds=MPH).
230 miles is not THAT bad for distance on a tank - how many gallons do you put in for the fill-up?
Tom
Tom
i put in 9.5gallons of gas each time...and most of the time i get about 210miles but sometimes it goes up to around 230miles......anyway, thanks a million for all your help TOM, i hope i can figuire out my problem soon...thanks again
I had a '91 Ford Exploder... literally. With a cracked block you'll noticed that the performance is lacking. most of the time you won't knotice it until you get into the higher RPMs. especially if you climb hills (grades). Never assume people are ligit especially if they are selling you a "salvage title" car.
Something to try is, unplug the 'hot' + cable from your battery. If for some reason the ECU is jacked up, sometimes this will correct it, then it does a remap the next you fire it up.
i drive on average freeway commute about 80mph (speedo) and get 280-300miles on a tank, my car is otherwise stock.
Originally Posted by superboxcarxb
i topped out at 75, before is slowed down b/c of cops. the top speed over here is 55. super sucky, makes me feel like everyone should just ride bicycles. but it's not like you can go anywhere. i live on a rock. and theres a jam everyday.
I have cousins on Kuaii, and they don't seem to complain about the speed limits.
Originally Posted by krustytheclown
Originally Posted by stangdude22
Yeah, need to know if its an auto or manual. I dont know how u managed 125, but I have gotten my to 105.
Also, you have 5mph more untill you run into an space time continuem issue.
Originally Posted by Knoxbox
... ive seen every bit of 120...
thank you buckod! maybe that is my problem but how can i find out for sure that is crack...i did unplug the hot cable and also the ground at the same time before, but it not solve my problem..??anyway,,,thanks
I'm really beginning to think this guy is a troll.....stop feeding him.
