REALLY NEED HELP,,,my car won't go over 83mph ?????
Excellent thought, Gardiner! Considering the various bits of info we have gotten from the OP, it could easily be the Throttle Position Sensor adjustment, or the Throttle Cable adjustment. Either could cause the listed problems and either would fit the dribbles of info we now have.
Here's the section of the repair manual that covers the removal and installation of the throttle body, and the installation portion covers adjustment of those two. Just simple tools, no special test gear.
Good place to check.
Tom
Tom
Originally Posted by Knoxbox
... i've used the portable gps, and ive hit higher than 103 in my xb and i have no modifications to the engine, just 2 inch goldline drop springs and some vinyl stickers but i suppose those will increase areodynamics of my vehicle and boost me 20 mph.
If not, what MPH did it show?
Variations in stock cars, or maybe even lowering, could add a few MPH.
What GPS do you have?
It says Tom....never trust something that days Tom.....
......Well except maybe for Tomas....but he's got that freaky avatar that stares and blinks at you....
IM KIDDING TOMAS....please dont ban me.... (Im not grovelling....well not in public at least)
Music City Scions
Originally Posted by tphan80
it seem like its unable to ship to the final gear because 83mph is max that i can drive, doesn't matter how hard i hit the gas padel. my car is automatic..
how bout you count as it shifts and see? its not hard to figure out a shift you can start there if it shift 4 times then you know if its tachin out and not shifting a 4th then you know. if it shifts 4 times then its not tranny related unless its shot
Originally Posted by Gardiner
If my speedometer reads 70, my Tom Tom shows 64. I have the stock 15 wheels and tires on my xB.
Scion's test data shows its top speed is a true 103, which might indicate as over 115 because of the way the speedometer is geared.
Think of how that affects gas mileage when you use the odometer to figure it out. You think you are getting 33mpg and maybe only getting 30mpg!
While the speedometer is DESIGNED to show an artificially high speed, but the odometer is about the same amount off IN THE OPPOSITE DIRECTION.
With the stock tires and wheels you are actually traveling FARTHER than the odometer indicates, and therefore getting slightly BETTER mileage than uncorrected calculations would indicate. (The usual error in the odometer with stock tires and wheels is about 3%, which would require multiplying the raw MPG figure by 1.03...)
(Covered many, many times here on ScionLife.)
Tom
Music City Scions
Tom
yea if ur O/D is messed up, you might as well put a hitch on ur car and tow things because that is the general purpose of O/D, to lower the amount gears or ratio for better hauling thats why you car will slow down quicker when accelerator is not being used. That sounds like when i switched my GMC Envoy into low 4 wheel drive mode, higher Rpm's but mostly torque is attained in that effect. wouldnt do over 45mph but 4 wheel hi did up to 80-85mph
Originally Posted by hxckid88
Originally Posted by heyitzdrahcir
Wow. You guys all top off at under 100. That's kind of... sad. Where do most of you guys live? I live in SoCal and everyone drives 80-85 on average on a clear night. My xA has topped out at 111, but that's because I didn't want to keep trying to accelerate and get caught by cops.
My box has seen 100 so far. A good 45 MPH to go before matching what a bone stock 1987 Supra (non-turbo
