Revhard turbo information
Originally Posted by TheRedBox
Originally Posted by SoCalbBox
FWD there's your problem :shock: :D
too bad they were asking 19k :shock:
Anyways as far as the rev hard turbo comes along, I got to ride in the car @ exposed. Didnt get to boost much because they didn't finish tuning it, but i can tell you that it sounds nice. They havent given out specifics on the car but i overheard him say 158WHP @ 7psi. And that's what they have done SO FAR. so lets hope tuning will up that. That is also with RHs 2.5 exhaust. They are using 2 additional injectors, and i believe a pump/regulator i think. Anyways the kit looked good. and one more thing.. sched release date is a month and a half WITH A CARB #!! :D
wait, wait, wait...I think the more important thing is how the hell did I miss this test drive you got? I didn't even see the car at el toro. Where was it and did anyone take any other pics of the setup?
I totally forgot to take pics!!!!!!!!!!
I have no idea how i got setup with the test drive. I just saw the rev hard reps, and started talking to them. Asking them about this and that. Then i asked if they wanted to see my box. Then asked if i wanted to see their box. then the driver of the box wanted to see my box, so i got to ride from the socal side to the norcal side. Too bad the tuning wasnt done, othewise i could have gotten a good 2nd gear run somewhere.
actually, runnin 7 psi on a 10:1 compression engine wouldnt warrant an "effective" 15:1 compression ratio. an engine reaches is peak cylinder at TDC as you all know, and according to Corky Bell and many other combustion engine theorists, force inducting an engine actually doesnt raise the cylinder pressure dramatically...rather it maintains pressure in the cylinder for more of the crank's stroke (which is why FI is so much better for the engine and driveable than a similar output that is all motor.) its not inconceivable to think that 7psi would work fine...especially with the reputation toyota has for building motors.
the only time i've seen 7psi not work well is with the REALLY high compression honda engine (like 11.3 and 12.5:1). just my .02[/quote]
Originally Posted by Indy007
The TRD Turbo Concept xB is listed as using a Garret T25R and 7psi of boost. No word on if the engine or tranny is beefed up to support it though.
He has a white xB with gold GT-N's. His car was at El Toro
Looking at your pictures one thing seems to jump out.
They are going to have to work on the hard pipe routing some more too.
If it won't fit with the "factory" accessory strut brace then it is not going to be successful.
Particularly when us RS1 owners all have the strut braces and a bundle of the regular xBs do to.
halosinfire
Scion tC 2G Forced Induction
Jun 10, 2015 05:21 PM
usedbike
Apr 9, 2015 05:55 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
