Squeal
Old 06-22-2018, 06:50 PM
michael73's Avatar
Default Squeal
1st Gen xB - I have a start up squeal identified as coming from the pulley end or the power steering area. Removal looks like it needs to be done from under the car, with the engine cross member removed for access. I don't mind, but it seems to be a fairly large
labor cost to access and then replace the parts in the way. Having just done a Lower Control Arm passenger side, and front disc brakes and rotors, I'm familiar with that side, however not wishing to suspend the engine and remove the cross member..
Ideas?
Last edited by MR_LUV; 06-22-2018 at 10:58 PM. Reason: Moved to Correct Forum by Administrator
michael73 is offline
Old 06-24-2018, 05:31 PM
Super Moderator
SuperMod
MileHightC's Avatar
If the squeal only happens at startup I would believe it to be one of your belts and there are two. You could try using some 'belt dressing', which I'm not a fan of as it tends to make a huge mess, to see if that remedies the squeal. If it does then I'd say replacing the offending belt would be in order and, while you're in there, it might make sense to just replace both of them as the other can't be too far behind.
MileHightC is offline
eignub
22
12-04-2023 08:09 PM
JoeSpeed
24
07-05-2017 10:34 PM
dgenem
13
09-19-2010 11:38 PM
streetracer99x
10
03-21-2009 02:52 PM
IceBox
03-25-2008 03:15 PM
Quick Reply: Squeal
