VVT and OCV replacement
Old Jul 21, 2015 | 03:38 AM
Ways808's Avatar
Default VVT and OCV replacement
So I got the old check engine light, vsc light, and traction control lights on. Ran it thru a OBD 2 scanner and got the P0012 error code. (Camshaft Position 'A' Timing Over-Retarded). My 2006 xB has about 105k miles on it.
Started small and hoped for just dirty oil causing the problem, so got an oil change and a flush, but the error code returned
So on to the next steps, checking for and possibly replacing a faulty variable valve timing (VVT) or faulty oil control valve (OCV)
How much should checking and possibly replacing these at the mechanic cost? Or, if I go a DIY route, do I need to drain the oil again to take out the VVT to check it?
Advice much appreciated, thank you!
Old Jul 27, 2015 | 03:52 PM
Sciota's Avatar
Default VVT
You don't need to drain your oil, From what I hear its hard to accurately test it . Its easier to just replace it.
Old Aug 2, 2015 | 08:13 PM
rjjablo's Avatar
Default Sensor
Facing the front of the motor there is a Camshaft sensor on the right. Pull it out and clean it off with some brake cleaner and a Scotch Brite Pad. Mine looked like a piece of Caramel and was over doing the VVT. No need to drain oil.
tato63
Scion tC 2G Wheel & Tire
9
Sep 30, 2015 09:55 PM
blh72
Scion xD Wheel & Tire
Feb 2, 2015 12:36 AM
eatcrispycreme2
Jan 30, 2015 03:43 AM
torranosaurus
Jan 28, 2015 04:53 AM
eric_m
79
Mar 17, 2013 12:21 AM
