XA_Transmission problems
Originally Posted by hotbox05
another question. how does a stock 914 pressure plate hold all of the power that a v8 conversion puts out? not even possible. the transmission yes , the pressure plate is WAY too weak too hold that much power. a miracle if true.
cause i've never seen a pressure plate designed for oh say 60ish hp , work with over 200 probably over 300 and still do an adequate job.
well he put it that way........
and you could make a pressure plate from a 914 trans fit a v8 flywheel if you drilled and tapped new holes and somehow the flywheels surface met up with the 914 press plate and clutch. if one so wanted. why would they? i have no idea.
when people dso swapos like that they use a custom clutch wit hthe correct size for the v8 while having the correct amount of splines to fit the 914 trans on the clutch disc. .
Originally Posted by bigkat_83
... On the street car(914) that I'm talking about it has a special flywheel clutch and pressure plate... I also have another V8 914 set up as a track car using a Tilton 6" double clutch with a set of six puck disks.
Those who come to Scions from V8s or heavy clutches,or from real sports cars, or that add quick-shifters and pistol grips, or that like to do speed-shifts and burn-outs -- they are the ones that have trouble with Scions. They are just inexpensive Tokyo taxis, yet so good that with care they can be used as sport cars and long-distance travelers.
RY_TC07
Jul 18, 2017 05:18 PM
