1NZ-FE Engine with Turboproblems
Old Sep 24, 2008 | 10:13 AM
lucas02538's Avatar
Default 1NZ-FE Engine with Turboproblems
Hello! My name is Lucas and I am coming from Austria!!!
SO I have an Toyota Yaris/Echo with an 1nz-fe engine with a greddy turbokit !
I have build in my car a exedy racing clutch, Crower Rods , Deatwerks 310cc,Cp Pistons with 8.5:1 and an greddy emanage blue one !!
So my engine donīt work well when i drive with 14psi the engine blocks at 4000rpm so what can i doo against it and how can i configure the emanage right !!
I have an wideband lambda too.
have anyone here a map for me or some other ideas to prevent the block at 4000rpm stumble
Best greetings from Austria!!
Old Sep 25, 2008 | 02:58 AM
java09's Avatar
ummm. im going to suggest getting it tuned professionally.. That will solve that stumbling issue.
Old Sep 25, 2008 | 06:20 AM
dexter_5000's Avatar
need to get an e-manage ultimate or aem fic to really open up the potential from what i undertand the blue doesn't allow you to tune very much and yes needs to go to a professional tuner.
Old Sep 25, 2008 | 07:24 AM
lucas02538's Avatar
ok so but i have read that it is the oe ecu that receive a signal from the maf over 4,4v and the it freaks out!!
so can i buy an emanage ultimate and use the terminal connectors from the blue one???
becaue i have intigrated the blue harness in the stock harness??
best grettings from austria
THANKS
Old Sep 25, 2008 | 03:00 PM
i doubt the pins are the same as the ultimate has more abiltities.
Old Sep 26, 2008 | 02:03 AM
blown_xa's Avatar
THANKS
the blue works fine, that's not the problem. I would purchase the Greddy Boost pressure sensor and connect it to the Emanage Blue, have it re-tuned on a load-baring dyno. 4000 Rpm is where the intake cam timing changes drastically from the toyota ecu, that may be the hiccup.
Old Sep 26, 2008 | 06:46 AM
lucas02538's Avatar
Ok I have a pressure sensor and the greddy profec e01 !!
Yesterday I have read that the oe maf is the problemmaker because it send over 4,4v and then the ecu switch in safe mode??
Maybe is this the problem??
Has anyone here a map that i can use as groundmap to build up from this??
eric_m
79
Mar 17, 2013 12:21 AM
Phatscion
16
Feb 17, 2004 03:26 AM
greenbox
9
Nov 18, 2003 04:11 AM
Infiz
Nov 2, 2003 11:32 PM
2fixA
Sep 29, 2003 08:36 AM
