going for 12's....
Old Jun 24, 2010 | 07:25 PM
  #61
blown_xa's Avatar
Ive concluded that my car is not good for drag racing. But I will still run the 1/4 to post up results. Yesterday I went to the 1/8th mile track a couple of minutes away from Ptuning and didnt do so well. 9.2 was my best... I ran a 8.9 with the small turbo and 60 less whp. The track however is not a good track as far as prep because my 60 ft was a 2.2. At MIR I pulled 2.000 hitting speed cut immediately. I still hit rev limiter at 7k in 3rd gear before the finish line but crossed at 83 mph anyhow.
Old Jun 25, 2010 | 05:26 PM
  #62
brett561tc's Avatar
run the quarter mile and see whats up. big turbo = back half car. your short time probably needs some work.
Old Jun 29, 2010 | 11:13 AM
  #63
usc_ty's Avatar
blown_xA, did you ever end up putting brake ducts in your car? I'm looking to do that to mitigate the heating of the brakes on track days.
Old Jun 30, 2010 | 04:45 AM
  #64
vk5112's Avatar
did u ever hit ur goal
Old Jun 30, 2010 | 09:52 PM
  #65
blown_xa's Avatar
Not yet but I found out in the last time attack I really need to. After 2 laps I lost a lot of braking because of the heat. I will be doing it before the next track event most likely.
Old Jun 30, 2010 | 09:54 PM
  #66
blown_xa's Avatar
Not yet man but I really havent been able to focus on it yet. Im certain running 12's is obtainable with the power I have now but I now realize having the power isnt everything, utilizing it is just as important.
Old Jun 30, 2010 | 10:12 PM
  #67
brainneeded_'s Avatar
wrd. if you make a gazillion hp and you can't put it down, what's the point.
Old Jul 1, 2010 | 12:40 AM
  #68
usc_ty's Avatar
Yeah I am having the same issue after about 2 laps as well. That's why I'd figure I'd ask you and see what type of system you devise. I took a look around the rotors and there's not much room to work with (to route tubing) so I'm curious as to what you plan on doing. I am going to try to remove the two plastic covers for where the fog lights go and remove the backing plate behind both rotors and see if that does anything.
sammydad1
Mar 22, 2013 11:34 PM
Haybale
Dec 25, 2012 05:19 AM
ih8civx
Jul 15, 2012 08:39 AM
SHHH_tC
Regional - Pacific South
Sep 13, 2011 07:29 PM
evilscion
Apr 19, 2004 02:51 PM
