hey everbody, new here, couple questions.
Old Mar 16, 2006 | 04:05 PM
IknowEverythingInTheWorld's Avatar
Default hey everbody, new here, couple questions.
First off, yes, I DO know EVERYTHING in the world. Just don't ask me any questions because I'm very selfish and unhelpful.
Anyway. I was on the fence for a long time about buying a new scion. I went another direction but I'd like to follow the progress in the Scion niche market.
Has anybody done a GTS engine swap? I believe it's engine code 2ZZ-GE.....
just curious
later
Old Mar 16, 2006 | 09:21 PM
ProshopXB's Avatar
I beleive its been discussed before many times, do a search and you will find it in a lot of threads.
Old Mar 16, 2006 | 09:26 PM
Crippie's Avatar
1UP Crew
what did you end up getting if I may ask?
Old Mar 16, 2006 | 09:34 PM
ProshopXB's Avatar
Here's a few...
https://www.scionlife.com/forums/vie...ighlight=2zzge
Hope this helps.....
Old Mar 17, 2006 | 12:02 PM
Yeah I figured it had been talked about. I was wondering if anybody had followed through. It doesn't look like it yet.
I really like the idea of making the xB faster, I like the looks, totally different.
I went with another pontiac...grand prix GTP. it's my 3rd GP.
I'm friends with BoogieQ. We've had a wild ride in the 3800 world. We worked on lots of cars, made LOTS of power, and had LOTS of fun. We actually had a shop for a little while.
I was sucked back in by the big cheap GM car with the supercharged engine that can make enough torque to snap the lug studs off like tooth picks. 400+ ftlbs is addicting. Especially when you can make that power for way less than $2,000!!!
Old Mar 17, 2006 | 12:42 PM
ProshopXB's Avatar
Yeah i dont think anybody has followed through on it yet, but if you got the money, time and the knowledge to put that motor in, then i say do it. Would love to see more power in our xB's. Ask BoogieQ how the mock supercharger is coming and to post some updates, thanks.
Old Mar 20, 2006 | 12:57 PM
I have been told there is progress being made. That's all I can say....
Old Mar 21, 2006 | 03:48 AM
black2doorecho1nz's Avatar
You make 400ftlb's for way lessthen 2000 but for how long and what is the actual savings in the long run for fixing a big cheep GM. Also you need 400ftlb's to get that lumbering boat rolling and you burn enought gas to fuel a small country. At least with a turbo 4 you are not always on boost depending on on crank speed. As far as cheep GM's go you get what you pay for. If you buy a cheep GM you drive a cheep gm on a daily bases. But if you like that sort of thing then to each his own.
Old Mar 21, 2006 | 04:01 AM
As far as the 2zz-ge install goes i have not seen anyone do it yet but i would like to see it. It would have a very good power to weight ratio. I would like to see it installed in a 2035 lb 2 door echo and turbo'd. That would make for a killer street sleeper. That would blow away lots of push rod punks.
Old Mar 21, 2006 | 04:11 AM
{edited --Tomas}
Old Mar 21, 2006 | 04:57 PM
True, it won't last long. That's why we just swap pulleys from the track/street. Takes about 2 minutes to go from 400 to 350 to 300.....
There are also a myriad of electronic gagets to adjust fuel ratios and timming.
For fuel mileage...you would be surprised. 3800's are rated 18-19 city and 28-29 highway stock.
My modded 99 would see 30-34mpg freeway (55-60mph) and 27-29mpg (65-75mph) The beauty of moddifying is you make more efficient power, less fuel is needed to MAINTAIN speed.
GM is also running stupid tall gears. 55mph and I'm seeing 1450-1550 rpm. 106mph at the top of second and 3rd...haven't been there yet, past 136 though...
This is very insightful.
Old Mar 21, 2006 | 06:43 PM
RTon20s's Avatar
Originally Posted by black2doorecho1nz
{edited --Tomas}
It is funny that you come in here and talk crap about all of these cars because you think it is "safe" inside a Scion forum. Meanwhile, you are trying to figure out how to make your little econo-coupe keep up with all of the cars you talk crap about. Even the base models of all of the stock cars you mentioned could probably run circles around you. (Save for the 2.7 liter Magnum V6.)
Before you go running your mouth about performance oriented coupes, sedans and wagons you may want to perform a reality check about the $10k gutless wonder you are driving around every day. You need to realize your cars role in the whole scheme of things. If you want to talk down about the other cars you mentioned, you might want to start talking fuel consumption instead of horsepower
Old Mar 21, 2006 | 08:15 PM
I drive quality not quanity. My echo come from factory at 16.5 at 84.5 1/4 mile and 8.4 0 -60 and i can go around a turn without hitten the ditch . At 5 psi and 155 crank hp i would have a power to weight ratio of 13.12. Not bad for a gutless car . By the way your fuel economy #'s are in your dreams bubba. You have to burn gas to make power .So your eather bs on the economy #'s or on the power . Witch is it buddy. Unless you live in dream land where hotrods can turn and your outdated pushrod crap runs on pixy dust or maby your the one on dust.
Old Mar 21, 2006 | 08:26 PM
I owned a 1980 cutlas that had 155 big hp . what garbage i sold it for a tacoma 4 cyl with 150 hp.If it were up to me we would use that pushrod crap for boat ankors.
Old Mar 21, 2006 | 08:43 PM
As far as safe goes tell me a form that is not safe so i can call you out on your pushrod outdated crap their .
Old Mar 21, 2006 | 09:35 PM
RTon20s's Avatar
Outdated or not, my '99 Dakota R/T with the old Western Chassis drop would run circles around you on a road course and leave you at the starting line at the drag strip. The only place your little Echo could outperform that truck would be fuel economy. Just like I said before.
And you can talk all you want about "if" you had this and "if" you had that all you want. Fact is, you don't have it. You drive what I can only assume is a stock, bottom of the line, Toyota. A Toyota that did so poorly in sales that they pulled it from the American market after only a couple of years.
Old Mar 21, 2006 | 10:18 PM
Your dakota is the best you can come up with. you wish it could run circles. I HAVE QUITE A LIST OF MODS including wider and lower tires preloaded frunt anti role bar with poly bushings frunt and rear strut tower braces frunt lower frame brace rear lower frame brace lowered in rear1.5 inch 2.5 inch short ram cold air intake positioned behind the head light boxed in with cold air vent in bumper. 2.5 inch catback exhaust and jet v-force PCM.also short shifter with steel mounting bushings manual fan switch . i have a mitsu. turbo to be mounted in the summer and as far as the base modle goes it's the same drive train but without all the electronics and 4 doors . I picked the lightest modle for that reason something you wouldent know about because you drive big heavy pieces of ____. Right now i race and beat any grand am gt or grand pre gt and even run down mustang gt's on twisty roads just wate until i put that turbo in bubba.
Old Mar 21, 2006 | 10:30 PM
I didn't buy it for the price iv'e had a 90 supra turbo a 96 tacoma a 90 tircel a 76 volvo a 87 toyota 4x4 a 85 626 1993 pathfinder and unfortunatly a 80 cutless. When i buy a car or truck it's not about the biggest car i can get for the lowest price possable. Talking about poor sales your good old big 3 are going down fast supin about peoplr dont want cheep crap to fix all the time . Say good buy to your belovied gm cuse their first to go
Old Mar 21, 2006 | 10:33 PM
no one is willing to pay good money for that american ____ anymore so they better shape up or get the f*** out.
Old Mar 21, 2006 | 10:35 PM
RTon20s's Avatar
LOL... I give up. This is going to get ridiculous. I concede. You are right. Your tuned tin can is the baddest hot rod on the road. You be happy in your tin can, and I'll be happy in my gas guzzling boat anchor of a Dakota, my daily driver Prelude SH, and the wife's fuel sipping xB.
No matter what we do none of them will ever be the car your Echo obviously is. I guess I should call my dad as well and tell him he is wasting his time with all of those Shelby Mustangs he has. I bet he doesn't even know what piles of crap those things are. Ancient pushrod technology and all. He should sell them and buy fleet of Echos. Or maybe just sell one of the steering wheels and buy himself one Echo.
