Installing tC Injectors on my xA?
Having problems, car will not start.
Do you have to use tC injector clips for Injectors to work.
Also have a Perrin fuel rail and ameature mechanic.
Need instructions on how to install these Injectors, I am having problems.
Please forward me instruction, or let me know where I can find help.
____
____
You actually got the TSI kit to work?? That alone is impressive. Now do you have a wideband?? I think tC injectors are over kill especially with a fuel rail. Im running with 2ZZ-GE injectors and my car is running HELLA rich. 310-320cc's is more than enough, while the tC put down 380cc's (if im not mistaken). The injectors should be plug and play like any toyota injector, but maybe your putting TOO much fuel in and of course its not going to start, the air/fuel mix is out of order.
^^^^ My first set of injectors were from a Celica GT (1ZZ-FE), they threw WAY too much gas in the mixture, so i removed them and went back to stock. Now that im turbo i bought Celica GTS (2ZZ-GE) found those on eBay for about $80.00. You just gotta keep on looking and one day you will get lucky like i did.
I used tC Injectors in my Box when I had the Blitz SC installed and they worked great.
If your car doesn't start with the tC Injectors, will it start if you re-install your factory xA Injectors? If so, I'm betting you have a faulty Injector or injectors!
I highly doubt your getting TO MUCH fuel where your car wont start. A LOT of people use tC Injectors in their xA/xB's and have had no problems.
__________________
__________________
Scionxa180
Oct 3, 2016 06:38 PM
mjonz20
May 23, 2011 09:15 AM
