Most HP made...
Old Aug 30, 2006 | 02:04 PM
Simplyscion's Avatar
Team No Limitz
Originally Posted by Sciond
Matchbox did 171hp to the wheels on the same type of dyno ZPI used a Mustang Dyno and a Power Enterprise SC
actually, it was only 141whp @10 psi...and yes he was the highest whp manual back then with the 141 on a mustange dyno...it was at the same time that I put down 123whp on the automatic @ 6 psi....he was running the PE and I was running a T20
Old Aug 30, 2006 | 05:32 PM
rollhard's Avatar
Thats the same power Im making now. I can make it on the dyno but cant put it down on the street because of the ECU. The dyno can only simulate road conditions so much.
Old Aug 30, 2006 | 06:13 PM
Team No Limitz
naa...you can put it down on the streets...only for about 10 minutes though until it starts making corrections
I wish I woulda cranked up the boost a lil bit on the dyno cause I woulda been putting down the same numbers as him if not more @ 10 psi on an auto
Old Aug 30, 2006 | 06:15 PM
dgHotLava's Avatar
why can't you put it down to the street???
do you have any piggy backs???
Old Aug 30, 2006 | 06:40 PM
rollhard's Avatar
There is a problem with our ECUs and how they try to maintain a certain AFR. In WOT, which you do to make max hp on a dyno, the ECU dumps fuel in for safety reason. Before WOT, the ecu is in somewhat of an economy mode. When you are driving on the street, you cant go WOT off the line at a light. So,,....in normal driving, its kinda on or off because 60% throttle and boost the AFR would be too lean.
Old Aug 30, 2006 | 06:54 PM
dgHotLava's Avatar
i know about the ECU learning and correcting, but i had not gotten it to so lean that i was not putting down what i should have.
maybe there is more hidden in this thing and i don't know it....
are you running any piggy backs???
Old Aug 30, 2006 | 07:11 PM
rollhard's Avatar
I am using the Emanage. If i tune the Emanage to where it will run rich, the ECU will try to trim down so much fuel that the CEL will come on. The only time my car pulls hard is when i floor it all the way at WOT. Otherwise its just like a normal xb with a few bolt ons. Around 70% throttle if my car hits boost, the car will feel like it hit a wall, it wont go cause its so lean.
Old Aug 30, 2006 | 08:47 PM
dgHotLava's Avatar
hmmmmm....that is a bugger of an issue.
i'm not really showing that characteristic with the SC...but i'll pay more attention to see.
Old Aug 30, 2006 | 08:59 PM
rollhard's Avatar
You can also go super rich to the point where your ECU does everything it can to bring the fuel back but cant anymore. Its a battle of piggyback vs ecu. I tried that and with my logger, it showed the ECU pulling back -45% fuel. haha, that is a LOT
Dirtyboy25
Oct 16, 2012 01:15 PM
Ghosty44
Aug 11, 2010 05:23 PM
daffy12
Regional - Pacific South
Jul 29, 2009 10:49 PM
TCpete
Jan 28, 2008 11:46 AM
