2 Head units in place of single double din?
Old Feb 4, 2007 | 04:17 AM
Slomo's Avatar
Default 2 Head units in place of single double din?
Hi, I used the search but cant find anything that talks about this, maybe someone can help. Ill keep it short...
Can you install 2 HU's, ie. a Flip out dvd player on top of a normal HU, in the double din location?
Thanks
Old Feb 4, 2007 | 05:35 AM
TerribleTed's Avatar
I am sure you could....but why would you want to??
Old Feb 4, 2007 | 07:30 AM
SanchezHacker's Avatar
Default Re: 2 Head units in place of single double din?
As long as you never turn them on at the same time there shouldn't be any electrical reason why you couldn't. If you did turn both on at the same time you might draw too much power(current?) through the factory harness and blow a fuse or worse. If your going to pursue this then I recommend you put a switch on there some how that would prevent both from being turned on by accident.
Old Feb 4, 2007 | 09:06 AM
tc-guy's Avatar
im sure because u can get a better deal on two h.u. (one as the flip out monitor and one as an in-dash dvd player. i had this setup in my civic before. u will be ok as long as u wire the flip out monitor thru an automotive relay so that it switches on when the in-dash dvd player comes on. there will be zero issues with blowing fuses. basically its like wiring an amplifier to the main h.u. (the indash-dvd). when u wire it this way u can turn off the monitor when u turn the dvd player off and vice versa.
Old Feb 4, 2007 | 04:43 PM
dmpsk8's Avatar
that setup would look kinda cool. jus throw an equalizer in the oven and you could have that thing lookin like a space shuttle
Old Feb 4, 2007 | 04:45 PM
Slomo's Avatar
Thanks. Thats just what I needed to know!
Old Feb 4, 2007 | 06:06 PM
tc-guy's Avatar
no prob slomo. just make sure u take pics and post when u done i would like to see!
Old Jun 19, 2007 | 02:11 AM
ShadowB0X's Avatar
Bump. Anyone have pics of a setup like this?
Old Jun 19, 2007 | 03:53 AM
city-soundzdotcom's Avatar
Its not to uncommon, google it.
City-Soundz.com
Old Jun 20, 2007 | 02:26 PM
Harleyguy's Avatar
no big deal, I don't have pics but do have a solution to stop both from turning on at the same time.... Use a relay with the first deck being the master. so when it is on it interrupts the power to the slave deck. so when you turn the master off, it allows power to go to the slave. you should also look into a way to seperate the rca's from both decks. I do not believe it is good to have power coming out from one go into another.
Old Jun 20, 2007 | 02:35 PM
NCBOX's Avatar
I have seen this done in bB's a;so
Old Jun 20, 2007 | 06:03 PM
ShadowB0X's Avatar
What kind car is this from?
Old Jun 20, 2007 | 06:55 PM
NCBOX's Avatar
WRX
Old Jun 20, 2007 | 11:01 PM
monoxide101's Avatar
I'm getting ready to do this. Right now my Omnifi control is taken apart so I can paint it black to match my head unit. Metra (# 95-8202) and Scosche (#TA1465B) both make adapter kits for double din units. Metra has instructions online on how to install two single din units using that. I'm just wondering where to get power at for the Omnifi.
Old Jun 21, 2007 | 03:09 AM
ShadowB0X's Avatar
Post up pics once you're done. I'll do the same. I've yet to see any pics of this type of setup in an xB.
Old Jun 30, 2007 | 08:52 AM
Adidude's Avatar
Depending on the head unit sometimes this is the only solution. One example is the top of the line Alpine F#1 stuff. The head unit only comes as a single din that supports DVD-A and DVD-V discs but does not have a screen and you have to add the single din flip out monitor. Another thing that you will sometimes see on competitor cars is not 2 head units but one single din unit and the controller for the Alpine processor mounted in a double din opening.
Old Jul 13, 2007 | 06:02 PM
dragonheart364's Avatar
I have pics of it in my myspace profile i put the dvd unit on the bottom, now i have a D3 http://www.myspace.com/dragonheart364
Old Jul 13, 2007 | 06:10 PM
Jiggaman's Avatar
Big Sky Scion
i am watching for pics on this one, good luck with the install!
sehall6h
Scion xD ICE & Interior
Feb 21, 2016 04:28 PM
clickclickw00t
Feb 18, 2015 08:57 PM
lunchbx05
Dec 11, 2014 06:13 PM
Renix
13
Feb 12, 2006 10:36 PM
bonzai272
Dec 28, 2003 09:51 PM
