added LED's to roof handle's
Old Mar 30, 2007 | 05:04 AM
  #61
raceronabudget's Avatar
Originally Posted by BurxBox
Originally Posted by raceronabudget
i already hollowed out the center ribs on the handles, but cant decide which color to get.
I just did mine tonite. they fit in there real snug, but you can use a small screwdriver and pop one end out and change to another color.
yeah i could change later... but why waste my time/ money. i'd get the infinite color, but no controller? i bet when i got them all hooked up i wouldnt be able to get them to change in sync. still cant decide what color.
Old Apr 6, 2007 | 10:08 PM
  #62
humpty111's Avatar
Originally Posted by Torq
Originally Posted by Romanova
Never mind... read the TECH. Looks easy! :D
yeah wasnt to bad at all, of course it was easier since I already had the cathodes and switch installed. I was also thinking about having them hooked up to the dome light but not really sure if I want it that way yet. I'm happy with just the switch right now.
Im gonna do the same but since i have the RS 1.0 i have leds in the cup holders im gonna run em down the center pillar and tap in under the seats.
but yeah the strips mounting local is excellent!!!!! Big Props!!
Old Apr 7, 2007 | 05:58 AM
  #63
ShadowB0X's Avatar
Did mine tonight.
Thanks for the great DIY.
I considered doing mine off of the dome light then changed my mind to go off of a switch. I am glad I put it off of the switch.
Old Apr 9, 2007 | 09:29 AM
  #64
kentae80's Avatar
N.G.S.O.
I ordered 4 green lights but 2 of them are on back order. So when I get the first 2 I will install them and wait for the other two.
Old Apr 9, 2007 | 08:00 PM
  #65
ShadowB0X's Avatar
I had the same situation. Its easier to do them all at once . . .
Old Apr 10, 2007 | 01:19 AM
  #66
xBster's Avatar
I guess I am adding this to my list of future Mods...looks really cool...
Old Apr 10, 2007 | 05:12 PM
  #67
Romanova's Avatar
Spend $5 on a 1/4" chisel and that center rib melts away like butta'!
Old Apr 10, 2007 | 07:34 PM
  #68
ShadowB0X's Avatar
You have to be careful chiseling though. You can "bruise" the plastic if you get too close to the outside of the handle. Then you will see light spots on the handle.
Old Apr 11, 2007 | 09:54 PM
  #69
low_wgn's Avatar
that is really cleaver...i would have never thought of that...nice work
Old Apr 14, 2007 | 02:54 AM
  #70
mk6111's Avatar
Is there a way to wire this into the switch that turns on the lights where your feet go? (I was suckered in and bought the factory ones and I have the switch near my handbrake / shift *** ) I was just wondering if I can hit that switch to turn on the floor lights and these ones. Also, how hard would that wiring be? I'm a novice, so if it would be too challenging or too big of a possibility to screw something up, I'd like to know. :D
Old Apr 14, 2007 | 03:01 AM
  #71
ShadowB0X's Avatar
It wouldn't be hard at all. Pull the wires from the grab handle LEDs along the edge of the headliner (you'll have to remove trim like B pillar to push wires up under headliner). Once you get them to the A pillar, ground both lights there then continue running your power wire through side of dash and to the footwell lights. Now just tap into the power wire for your factory lights (from switch).
Old Apr 14, 2007 | 05:17 PM
  #72
mk6111's Avatar
Alright, sounds awesome. Thanks.
Old Apr 15, 2007 | 12:02 AM
  #73
bfurches's Avatar
...so can i join the club?
Old Apr 15, 2007 | 12:26 AM
  #74
coregmrconman's Avatar
So I REALLY like this, If i buy the ones for computers, will it be just as easy, or are they different?
Old Apr 15, 2007 | 12:43 AM
  #75
bfurches's Avatar
probly fairly the same, but i swear by oznium!
Old Apr 15, 2007 | 01:13 AM
  #76
aeon's Avatar
bfurches... I'm so glad someone did this to their XA!
Love it! Any tips or a " how to " for an XA?
Looks awesome
Old Apr 15, 2007 | 02:54 PM
  #77
bfurches's Avatar
i will be making a video for SCTV on how to do it.
...i might even sell a kit with a preassembled handle and harness if i can get some interest.
Old Apr 15, 2007 | 10:16 PM
  #78
mplayboy72's Avatar
dude you should totally do it
Old Apr 16, 2007 | 04:02 AM
  #79
bfurches's Avatar
i will post up under the xa home section...
Old Apr 17, 2007 | 01:56 AM
  #80
samhain's Avatar
Could someone draw up a real simple diagram showing how to hook all four up to a power source and switch?
