Adding a cig lighter?
I want to add a cig lighter to my xB, inside the glove box for my ipod fm transmitter/charger, so its out of sight, but still close to the radio for good signal. How can I do this?
Originally Posted by DOHCtorJT
Autozone/Napa/Walmart sell an add-on socket. Usually $5-10. Then tap off of your existing lighter for power and put it where you want.
Originally Posted by Gamecat
You might want to also think about some sort of quick disconnect on it so if you have to remove the glove box it's not a pain in the booty.
To change the air filter you do. Or if you don't the person that changes it does.
At least in the XA it works that way.
p.s. I think they sell lighter sockets at autoparts stores, then just run wires to the back of the existing lighter and tap in there, or maybe just run one across to the fuse box.
yeah you can buy the cig lighter at autozone for like $6. Just run the power and ground to it and u can literally put it anywhere u want. I normally run it from the fusebox or battery....just make sure to fuse things off.
For an actual cig lighter that will be used for lighting cigs better put 25-30 amp fuse. If however you are only running electronic goodies you can and should use a lower value really maybe 10-15 amps...depends on how many amps the accessory draws.
^^ For 25-30A fuse, use at least 14ga wire. For 10-15A use at least 18ga.
http://www.powerstream.com/Wire_Size.htm
Figure accessory draw then select wire size then fuse accordingly!
This is a vw 12v plug out of a jetta. lit ring is red. VW also installed green lit rings in some of the golfs also. Junk yard free-bee
Here is the link, just in case my pics don't show (like always)... http://scionpictures.blogspot.com/
I simply piggy backed off the existing 12v. Then I tapped off the HVAC controls to run the lit ring when the lights are on.
Thanks for the input guys. Singleshot, you just cut the wires run to the original lighter, and spliced a 2nd set of wires to it? Have you had things pluged into both at one time before?
As long as your not engaging 2 cigarrete lighters at the same time it is unlikely that you would over amp the wiring or the fuse. Running 2 electronic devices with it wired that way would be fine. For best protection of the devices you are plugging in ...they should each be fused to a value for their rating between the lighter accessorie plug (often in the lighter accessorie is a fuse) and the unit itself.
I currently have 2 extra acc outlets in my xA.
I hid one behind the center console kick-panel that powers my GPS, and the second is run out just below the rear cupholder that powers a DC cooler I keep behind the drivers seat (great for keeping road-trip redbulls icy-cold.)
Both are tapped to the OEM cig-lighter power, and both get a 3amp fuse. The
I don't power much with either. The OEM one I use to run the radar detector (kind of a oxy-moron with an xB) and the new one I use for the phone charger. I did use both at the same time without issue....
I'd have to check again, but I think I used a 27mm hole saw for the vw lighter.. But that was for that specific lighter. I would imagine that each manufacture would be slightly different and you would want to be exact to make sure the fit is snug. The way they snap in is pretty cheesy, but it works.
No issues what so ever with using both at the same time, but I have never powered anything that took a lot of power.
singleshot
The last style Durango has some really nice 12v plugs also if you are in the market for OEM plugs. They have a spring loaded lid that says "12 volt" on it in white letters. Very clean..
Singleshot
singleshot
Singleshot
i use one for my cell phone charger one to light my cigarettes and the other was used as an ipod charger. using all three wouldn't work but since i've removed the ipod from the equation all is well.
i put the cell phone one in the same spot you did
I want one for my ipod and one for my cell. So splicing is fine?
And I wanna check the junkard for the Durango one, my parents have those style and your right, they are nice.
Your idea is good too hotbox, if worse comes to worst ill try that.
Thanks for all the input guys, really appreciate the help!
Klunkerbill
Nov 9, 2015 11:39 PM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
JonathonK
Aug 26, 2015 08:30 PM
