Almost had cold cathode dash lighting
Old Mar 27, 2005 | 09:26 PM
DarkBoxJr's Avatar
Default Almost had cold cathode dash lighting
Until they snapped. Anyway, from what I've noticed, a dual 4" setup would be ideal, and the wiring is super easy. The hard part, and the reason why the lights broke, is trying to find the best position for them. I wedged a single bulb between the tan plastic piece that holds the original bulbs, and the main part of the console, under the light dispersion thing. The result was very similar to a poorly aimed LED setup. I'm wondering if the clear plastic thing should be removed and replaced with the cathodes themselves. That would probably be the cleanest install. Now it's back to searching for 4" white cathodes, which are almost impossible to find.
Old Mar 28, 2005 | 12:17 AM
Max2k's Avatar
I have 1 4" in there. The middle is super bright, but the edges are a bit dimmer. I had to grind the blocks off the ends of the tubes to make it fit because the cathode lamp wouldn't come out of the plastic housing.
Old Mar 28, 2005 | 01:47 AM
richdog's Avatar
DelMarVa
Scion Tuners
where are you guys putting these lights? Any pics?
Old Mar 28, 2005 | 05:38 AM
DarkBoxJr's Avatar
Where did you put it? I was able to pull the tube out of the acrylic housing, which was like the beginning of the end of my project. Those tubes are way fragile.
randode
44
Jun 29, 2004 04:19 PM
randode
Nov 20, 2003 05:46 PM
Besk_one
Nov 17, 2003 09:28 PM
randode
15
Oct 31, 2003 09:50 PM
BlueBox
9
Sep 25, 2003 04:36 PM
