Amp blew a fuse... Violently
Old Mar 14, 2005 | 11:32 PM
Priory_of_Scion's Avatar
good luck finding a 3" (read...3 inches) grounding spot.
Old Mar 15, 2005 | 01:19 AM
Xbilly's Avatar
The fuse on the power cable should be equal or lesser capacity as the amp fuse. The shorter your power wire is the smaller the awg you can use. seven inches coulnt possibly too long for a ground wire could it?
Ive only gone through one fuse, i'll give it one more fuse and it blows it I'll retire the amp and go back to the stock scion sound.
Thank you everyone for the advice
Old Mar 15, 2005 | 01:35 AM
TurboMe's Avatar
Originally Posted by ScionDad
DO NOT OVER FUSE. If you put a 30 amp fuse in there the next smell might be your amp/car in flames.
right OVER-Fusing is a big no no
so what happens right now when you try to replace the fuse? Does it still burn out?
Old Mar 15, 2005 | 06:09 AM
CRxB's Avatar
get rid of the blade fuse holder and grab an AGU fuse and use a 30amp fuse. and its true about the 8gauge I would definitly change to either 10gauge or go 4guage so if you want to upgrade your amp to a bigger one you wouldn't have to spend for anothe kit.
Old Mar 15, 2005 | 05:21 PM
ugly_duck's Avatar
Hey thanks for that helpful post, Im sure they know hwat i meant FEET DAMNIT
Old Mar 15, 2005 | 06:25 PM
superjeer's Avatar
The fact that the fuse burned up instead of popping is the fuse's fault not your amp's. Another fuse SHOULD just pop, so don't worry about it . However, another fuse will just pop, so that is where my advice ends and this whole thread starts.
Old Mar 15, 2005 | 06:31 PM
coasterlvr's Avatar
Default Re: Amp blew a fuse... Violently
Originally Posted by Xbilly
My amp (an older mtx thunder 240) Blew the 20amp fuse shortly after I hooked up an infinity perect 10 vq
But i thought fuses were supposed to just pop, this fuse popped and burned and stank up my car...
is this a problem i should worry about or should i just replace the fuse and forget about it?
Thanks
So have you tried a new fuse yet? I assume your fuse was on the amp and not inline? If so that is never good if it blows there. Usually means somthing let loose in the amp. Try the new fuse and see what happens. I would be ready to disconnect the power from the front fuse if you see smoke.
Old Mar 15, 2005 | 07:12 PM
Reign_Man's Avatar
have u tryed taking the casing off the amp? make sure nothing is stuck or loose inside...or fried
Old Mar 16, 2005 | 03:23 AM
Xbilly's Avatar
I replaced the fuse in the amp with a 20 and i switched the fuse in the wire to a 15, and listened for two separate hours today, at first there was some cutting out, for a second, then everything was normal and no problems YET...
I have not looked inside the amp, im not taking it out of the car accept to throw it in the lake :p
Old Mar 18, 2005 | 04:06 AM
Xbilly's Avatar
The 15 fuse that i put in the wire blew (in a normal fashion) today after some fairly heavy bass for about 25 minutes. what should I do now?
Old Mar 18, 2005 | 11:17 AM
SCI_TC_GUY's Avatar
well.....it sounds like you kind of want to throw the amp in the lake.......so put a 25 in the wire and in the amp and have some fun......
Old Mar 18, 2005 | 04:40 PM
Reign_Man's Avatar
naw thats not smart. just replace the fuse and pwan it, then go get some buger king, cuz thats all ull get for it lol.
Old Mar 18, 2005 | 06:58 PM
SCI_TC_GUY's Avatar
but if he's just gonna toss it.....may as well blow it.......or take it to a pawn shop......if u need something to eat....
Old Mar 18, 2005 | 11:13 PM
Xbilly's Avatar
Lake... definately the lake... baseball bat first..
ok ok, any suggestions on what amp I should get? The closer to $100 the better but nothing over $220...
The sub I have is 400watt rms whats a good amp wattage for that?
Old Mar 18, 2005 | 11:43 PM
awsart1's Avatar
i think in order calculate fuse size you divide the rms watts by the voltage then you step it up to the next bigger size fuse beings they say fuses are only designed for 80 percent of their rating constantly so a 20 amp fuse is only good for 16 amps constant load so if you had a 200 watt rms amp you would do 200/12 and get 16.6 amps of draw so i would use a 25 beings thats right on the edge
prescottn
Scion tC 2G ICE & Interior
Apr 26, 2016 01:14 AM
DannyBoy65
Sep 21, 2015 06:23 PM
spharr62
Sep 20, 2015 01:44 AM
volume315
Aug 29, 2015 01:31 PM
volume315
Aug 29, 2015 10:28 AM
