Anyone farmiliar with wire color coding of dome light.
Old Aug 19, 2005 | 05:37 PM
Tobias455's Avatar
Default Anyone farmiliar with wire color coding of dome light.
Good afternoon all. This is my first post so be kind. By the way I did do a search to try to avoid posting my question.
I recently picked up a Gentex auto tint rear view mirror with Homelink and am looking to wire it in to the harness for the sunroof control which works only when the ignition is on.
My problem is that I can't seem to find any wiring schematics or diagrams showing the color codes for the wires. Right now I know that the red is constant 12V(tested it) but there are five other wires(black, blue, white, and two(2) white w/black stripe). All I need is a two wire hookup(pos. and ground.)
Now I've tried a few "safe" combinations but can't seem to find out which wire carries the 12V when the ignition is on. Any hep or ideas would be great!!!
Old Aug 19, 2005 | 05:44 PM
xnevergiveinx's Avatar
i'm not sure about the wiring, but you have to remember that the sunroof has 45 seconds to be operated after the car is turned off, unless you open the door...
it may just be in your best interest to run a wire up there, just so you know whats what
Old Aug 19, 2005 | 05:48 PM
ack154's Avatar
Moved to ICE...
Old Aug 19, 2005 | 07:09 PM
Tobias455's Avatar
Hmmm... that's food for thought. But I'm o.k. with it as long as the wire I tap into gets power as long as the ignition is on. I just don't want to tap into the constant power for the overhead lights. I'm sure the LED on the mirror would draw minimal amperage, but I'd rather wire it somewhat correctly.
Old Aug 19, 2005 | 08:26 PM
RanmaP's Avatar
Default Auto Dimming Mirror
If you got the OEM factory auto dimming mirror then you can e-mail (ranmap@charter.net) me. I think I can help you out....
The auto dimming was like my 2nd add-on that I did for my car.
Old Aug 19, 2005 | 10:11 PM
Tobias455's Avatar
Default Re: Auto Dimming Mirror
Technically yes and no. It is the same model made by Gentex with the Homelink feature. However it actually came out of a 2005 Nissan Maxima. I already know which wires power the auto tint, homelink and reverse power for the tint, and ground on the mirror itself. Basically I am looking for the knowlege of which wires to tap into to power the mirror when the ingnition is on.
MonsterunderBed0
Feb 17, 2015 08:42 PM
DR_xB
Jul 20, 2004 08:31 PM
fliggah
May 28, 2004 07:51 PM
DirtyThirty
14
Jan 16, 2004 04:48 AM
abbfanuc
Oct 21, 2003 05:16 AM
