AVN2454 Problems. Please help.
Hello, I bought an AVN2454 in February and have only been really using the navigation in my tC. When I installed it, I tested the dvd player to make sure it played but I didn't test it past the title screen.
I tried to use recently and noticed that I can't get past the title screen. If I try to press play or skip to the next chaper it says: "This function is currently disabled". I thought it was a parking brake grounding issue so I switched the ground from the screw behind the unit to the black/white wire that is connected to the cigarette lighter. Still the same problem. Still if it was the grounding issue, wouldn't the unit just not play the dvd at all?
Anyone have this problem and know how to resolve this?
Thanks
Thanks
Won't swear to it, but put the ground back to the deck ( the factory wire) THEN follow it down & move it from the emergency brake. I was told that the factory has some "special" bullcrap. My buddy moved mine after the same prob & now mine works fine. Best of luck!
ive gone through 2 screens and both i just wired to my dimmer ground and never had a prob, u might wanna try that. But im pretty sure it would say parking break or something and not even show the menu, but i guess its worth trying.
Thanks
Thanks
The AVN2454 has a poorly made DVD navigating menu. Sometimes those damn blue buttons would cover up the title menu on some DVD movies and you can't even see what your selecting.
The unit can be used with remote which is good, but only works with audio (mp3, CD, etc.) which sucks since you can't navigate when playing DVDs.
