Basslink turns off after 5-10 minutes
Hi, I just installed my basslink with 8 gauge wire and whenever I use it, even if the bass is low, the sub shuts off after a few minutes. 15 or so minutes later it will turn off and then will turn off again in a lil bit. Anyone with a basslink have this problem or know how to fix it. Do you thing I should run a 4 gauge wire?
Jay
Jay
I have the Basslink T (pic in link below) running on a 8ga wire, but never had that problem. You can also check to see if you auto-on wire is ok and not frayed or anything. Are you using a stock H/U or aftermarket?
thanks for the replies. I looked where I grounded it and there is paint there. I will sand it off tonight and hopefully that will work. Although before the unit powered, and now it doesn't even turn on.
Jay
Jay
cid_mcdp
Jan 5, 2015 02:45 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
