Bazooka sub factory harness question
Old Oct 7, 2006 | 01:06 AM
iKevin's Avatar
Default Bazooka sub factory harness question
I bought a Bazooka sub kit for my xB from a Scion dealer and i've decided to do the sub install myself. I've read and reread the instructions but i have a question that the instructions don't answer:
On the wiring harness there's the plug that goes into the HU (no problem there), then there's the dongle that plugs into the car's original HU adapter (no problem there). But there are these 3 other plugs (one Blue/White, one Red labeled 'turn on option 1', and one blue labeled 'turn on option 2'). Where do these go? (see pics below)
Any help would be appreciated. . . Thanks![/img]
Old Oct 7, 2006 | 10:30 AM
iKevin's Avatar
I did find that on the red wire labeled 'turn on option 1' that the wire says 'ignintion/switched (12V+)'. The blue wire (turn on option 2) says (power antenna). The unlabeled blue/white wire says 'ANT Turn-on (12V+).
So i'm guessing that to get the sub to work like the instructions say (sub comes on when the ignition switch is turned on) that I will need to plug the RED wire (turn on option 1) to the Unlabled BLUE/WHITE wire (ANT Turn-On). . . . That sound about right to anyone?
Old Oct 7, 2006 | 04:16 PM
iKevin's Avatar
bump
Old Oct 7, 2006 | 05:41 PM
Supertech's Avatar
Hey Kev,
Send me a PM with your email addy and I will send you the official Scion Bazooka Wire Harness and Radio Schematic. It provides a full description of all the wires in the harness.
Old Apr 19, 2007 | 12:56 AM
samhain's Avatar
Did you ever figure this out?
Old Apr 19, 2007 | 02:25 AM
DriverXa's Avatar
I'd like to know how it tuned out. Also, I was thinkin of doin this also but instead of puttin in the 8" 100watt tube I was goin to put in the 10" 200watt tube and just wanted to know if the wiring harness can handle the extra power or not. Thx.
Old Apr 19, 2007 | 03:11 AM
iKevin's Avatar
I used the red one and it turns on when the ignition goes on.
Old May 13, 2007 | 02:55 AM
STPrime's Avatar
that is totally different then the wiring harness they gave me. i wonder if that's why i'm having problems with mine not working.
Old May 14, 2007 | 12:17 AM
iKevin's Avatar
Very well could be . . . . Did you buy the actual Scion kit or just the standard Bazooka model that looked like the Scion kit? Because i think the one you buy in stores has a slightly different harness.
Old May 14, 2007 | 01:55 PM
STPrime's Avatar
i bught it from my scion/toyota dealership.
also, i was trying to ground to the shocks and i think that is my problem.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
NewBox06
Feb 3, 2015 12:36 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
