Bazooka Sub Install Help!
Ok... I ordered the sub for my tC from mcgeorge. I finally got around to putting it in today, and all in all, things went pretty good. You have to essentially remove everything in the car from the trunk all the way up across the passenger's side and into the dash, so it is a fairly involved process. The only problem I had is when it was all hooked up and wired, the damn thing doesn't work - no sound comes out.
The manual only has the most basic of troubleshooting info. The thing is there is a little green LED on the sub, which is lit, so I know it's getting power. The manual says that if the LED is on but no sound comes out, one or more of the speaker wires is disconnected. I'm not sure exactly how that works as all 6 speakers are working, but I guess it means that somewhere between where the leads from the sub come in at the deck and the sub itself something is wrong? Anyone have any ideas of what to test? This is really killing me...
Thanks in advance...
Originally Posted by hornet_on_flower
all i can think of is check your wiring
not much help i know
anyways, keep the thoughts coming
Need more info. Pm for I do stereo installs and am a dealer of Bazooka. I am willing to help out. Did you use rca input or speaker level? Is it a tube or something other? Just a couple of ?'s I have before I can continue. I will be at work soon so bear with me as I may not respond too quickly.
1. A prebuilt harness with grounding that plugs into the deck on one side (the stock stereo plug daisy chains through it) and the enclosure on the other - both molex connectors.
2. A "box" which fits right into the side of the trunk with a molex connector on the back of it for the wiring harness. Inside it has it's own amp, and on the front of it is a 10" bazooka woofer.
So I guess I'm using speaker level input, but I'm just using the prebuilt harnesses. Now I know something is working because the LED on the box is illuminated, so at least the harness is passing some power, but maybe one or more of the speaker wires in the harness is broken, or maybe the amp is broken, or maybe the wiring between the harness and the sub is broken? I don't know how I'd go about checking any of that. The instructions have the pinouts on both the stereo and sub side, if that would help I can post them.
Thanks!
Disclaimer * The only way your problem will be solved is if we cover everything throughly.
So if this seems like a stupid question.. then at least we have this ruled out.
Are you sure the sub isn't working ?
Did you have the volume turned up when testing ? Did the music you were testing with have bass ?
Depending on the amp thats included the sub might not make any noise when listening are reasonable levels.
C
C
C
C
Ok - I think I got it figured out. I didn't have time to do more testing, but it looks like one of the pins in one of the harnesses was loose or disconnected. I took them both out, checked them, and plugged them both in and it's working now!
Thanks for the help - I know it's always something small, but it gets discouraging after you tear apart your new car and you can't make things work. Thanks for keeping it bearable.
TheRedBox
31
Dec 2, 2003 04:53 PM
