The Best Amp?!
Old Mar 18, 2004 | 10:11 PM
scionspecialistvegas's Avatar
den, thanks for the input, this is needed. Bill
Old Mar 19, 2004 | 03:20 AM
ScionRI's Avatar
sIcKsCiOnS
how much and where do i purchase crossfire amps? specifically the 300w mono D
Old Mar 19, 2004 | 03:37 AM
ScionRI's Avatar
sIcKsCiOnS
also im looking at the phoenix gold ti 500.1 mono... 227 a good price?
Old Mar 19, 2004 | 04:07 AM
rampagesd's Avatar
get an amp that will put out double of what your sub requires. you'll have more headroom and play in your system. also remember distortion is the number 1 killer of speakers which occurs when you under power something.
Old Mar 19, 2004 | 04:20 AM
Piston's Avatar
I dont know why I didn't say anything before, but I have a brand new xtant 3001 amp. It is 300 watts RMS at 2 ohm. I will make you a great deal on it. I have 3 I used 2 on a set of comp speakers, and I had one for a back up. It is a nice small amp. 9.5" x 12" x 2". Titanium grey is the color.
Let me know if you are interested.
Jason
Old Mar 19, 2004 | 06:58 AM
DenZinz's Avatar
High current Class "D" mono subwoofer amplifier, 150w x 1RMS into 4 ohms, Variable Lowpass Crossover from 50 to 250Hz, 5 way protection circuits, MOSFET power supply, CFR-3 analog bass booster, 300Wx1 RMS into 2 ohm at 12.5 volts 8"W x 2.1"H x 9.5"L
Sorry Jason. had to post a pic
XL Audio
401-641-1381
76 Putnam Pike
Johnston, RI 2919
Drivers Side
508-699-6600
13 Taunton St.
Plainville, MA 2762
Reagan Audio Design,LLC
781-769-3320
100 Broadway
Norwood, MA 2062
Elroy you are correct. A lot of people dont realize that either.
Old Mar 19, 2004 | 01:53 PM
eugovector's Avatar
But what happens when you over power something? I'm having fears of sending 400W to a sub or speakers meant to handle 200W. Plus, aren't most high-end amps rated to run at full power w/o significant distortion?
Old Mar 19, 2004 | 02:30 PM
Docsnuff's Avatar
sIcKsCiOnS
DelMarVa
Scion Tuners
Originally Posted by unlmtdndeavor
ok...first...the info that im gonna provide may be shocking to some...but true
you dont need to spend 300 on an amp where u need so little power. get the bazooka el1500, yes bazooka. although it can be bought for around 150, this amp is outstanding. i used to run this to two 4ohm alpine type r's and my friend has them going to 2 12" kicker L7's. a great amp for the money and it wont bust on u. good luck.
Thats what I have, but I have 2, they each power their own 12" Type R!!! Great bass, they were installed in the mustang, and if my xB ever arrives they will be in it very quickly!
Doc
Old Mar 19, 2004 | 03:20 PM
DenZinz's Avatar
I think you have to use common sense. I think what Elroy was trying to explain is that, dont put 100watts amp into a sub and turn the gain all the way up and your radio all the way up just to get more bass. That will cause a couple of problems. One your radio is probably clipping causing it to send distortion to the amp. Second, the gain control is only to level match the head unit and not a volume control. If you are saturating your input then you are also sending distortion to your speakers. Ive seen a lot of systems where you can only turn it a 1/4 way and the speakers are bottoming out. A system is designed to be turned close to max and not cut out or distort (depends on the radio).
By putting a 400w to a 200w sub and tuned properly, you will be ok.
Old Mar 19, 2004 | 04:02 PM
scionracerxb's Avatar
I got the bazooka amp too. great quality and sound for the $$$
Old Mar 22, 2004 | 03:23 AM
ScionRI's Avatar
sIcKsCiOnS
bazooka owners.... you are really happy with your amps? and... what kind of speakers are you running off them (i know the L7's, what rms do they need.)
also: where did you get yours? for how much?
Old Mar 22, 2004 | 03:59 PM
I"m running the bazooka N.O.S. look tube with a 300w bazooka amp.
Old Mar 22, 2004 | 04:34 PM
obz's Avatar
obz
If you guys want a crazy amp that is show quality, look into the Zapco amps. They're made in my old hometown Modesto!! All you need is a 100 watt amp and it'll power 15's. It's the cleanest most powerful amp I've ever heard!! Course you won't touch one for less than $500. :twisted:
Old Mar 23, 2004 | 08:57 PM
ScionRI's Avatar
sIcKsCiOnS
well then..
Old Mar 23, 2004 | 09:08 PM
UrbanDrum's Avatar
The OG Kicker ZR1000
The older one though cause the new ones are crapola.com
Old Mar 28, 2004 | 03:51 AM
19_inch_box's Avatar
memphis car audio
Old Mar 30, 2004 | 01:53 AM
ScionRI's Avatar
sIcKsCiOnS
settled on a pg 500.1 octane series with remote and an IDQ d4 v2
Old May 25, 2004 | 10:25 PM
cme42ns's Avatar
Default Best amp
Originally Posted by DenZinz
Originally Posted by dchan8
Originally Posted by scionxb04
if your only driving subs
http://cgi.ebay.com/ws/eBayISAPI.dll...category=39737
800rms into 4ohm load
about 1200rms into 2ohm more power then u need to give u a headache with subs that could take it
282 to your door not bad if your on a budget lookin for power
i agree - rockford has been around for a while and they are made in the us, i'm using the 400 model and it fine for my 2 12 type r alpines. i'm using hte 801s in my other car and think it is a little extreme.=) but who cares bass is meant to be felt.
Don't be fooled...RF use to be made in US. Not true anymore. Some of there skus are made in the US but the majority is overseas.
ScionRI
how much will the quality of the amp play in as a factor here? will there be a noticable difference in sound to a relativly green audiophile? (this is my first system i'm building, so naturally i need pointers) If it is so noticably better, then the new mission is to find the lowest price i can get one!
It does make a big difference on how it controls the subs. Inexpensive amps will perform sloppy and muddy. Also take note that not all specs are 100% accurate.. When the new CEA rating come out, it will tell a lot about a amp.
Denny,
From one manufacturer to another, I just want to let you know that ALL Rockford Fosgate amplifiers AND subwoofers are manufactured in the United States.
These forums are an excellent way to make consumers aware of cool products, let's not mislead them too much.
Old May 26, 2004 | 12:21 AM
RICHXB's Avatar
You want amps that rock the box,and sound clean check out Zapco or ARC audio.
prescottn
Scion tC 2G ICE & Interior
Apr 26, 2016 01:14 AM
DannyBoy65
Sep 21, 2015 06:23 PM
crimson10tC
Sep 10, 2015 08:44 PM
volume315
Aug 29, 2015 01:31 PM
volume315
Aug 29, 2015 10:28 AM
