busted my sub?
I was on my way home tonight and was startled when my subwoofer started rattling loudly. I could here the rattle over the bass and all the other rattling it causes. so I parked it and popped the hatch to listen and it sounds like its coming below the speaker inside of the ported enclosure. I have a kicker L7 and the amp I have does not push as much wattage as the sub(only about 850rms) can take so I find it hard to believe I messed the sub up. I don't know what would be causing that noise. its so loud I had to turn the system off because I couldn't here anything but the rattling from inside the enclosure. the sub was to hot to touch but I'm assuming that's noromal.
any idea? I want to try and fix it before sat!
thanks!
thanks!
It is not normal for a sub to be too hot to touch. If it was that hot the sub is probably blown. The rattling sound it's making indicates that also.
Just because the amp's rating is less than the total power handling capability of a sub does not mean the amp can not blow a sub. If you have an amp that is rated lower than the sub and you run the amp into clipping, the power output of the amp can be enough to blow the amp. The clipped signal of the amp has more power than a clean sine wave. This extra power results in excessive heat which ultimately will blow your sub. Think of it as area under the curve in math. You will have more area (power) under a square wave -|_|-| than you will under a sine wave /\/\.
Best advice is to replace the sub with a new one and adjust the gains of the amp to keep it from running into clipping. Heat kills subs.
Mish
Mish
When a speaker "blows" it means the voice coil has failed. The voice coil can unwind from the former, burn, open, or short. Either way the problem can not be fixed by you. The sub will need to be relaced or sent back to Kicker to be reconed. Sorry.
Mish
Mish
A ported enclosure will unload or lose control below the tuning frequency of the enclosure.
This can be a cause of speaker failure if your not familier with the sounds a speaker can make or if your putting too much power to the speaker.
Im not sure about the L7 drivers but the power rating your talking about might be for a sealed enclosure.
The only way to really be safe with a ported enclosure is to use a subsonic filter set to the tuning frequency that way you can put asmuch power as the driver can handle and not have it unload.
excellent info in here...
Having your gains set to amplify a lower voltage signal than you're sending through your RCA's (gains turned up too high) will cause clipping and ultimate demise of the sub in one way or another....
only way to actually test it is with an Oscilloscope. A good stereo shop should have one... other than that, just turn the gains all the way down, and turn the volume of the HU up as far as possible untill you hear distortion through the regular speakers (you'll know when it distorts), then back it off a notch or 2. This will be your MAX HU volume. With the HU at the MAX you figured, start turning up your gain untill you hear distortion in the sub, then back it off a little. That's all there is to successfully setting your gains.. just remember to not turn it up past the "max" point of the HU volume because that's where clipping will start.
ok that makes since no because I would turn the HU up till I heard distortion in my stock speakers and jus turned it down a couple clicks and left it because I didn't here any distortion in my sub. lesson learned. next one I get i'll try and tune myself. need to start learning how to do this stuff so i'm not always taking it to the shop. jus gota wait till I get some $$ to replace it.
would a more powerfull amp help prevent it from clipping?
nope.... more power only = more volume.... it's the gain setting that causes clipping....
thanks!
thanks!
If you still haven't found anything, either post here again with what you've observed for more assistance or go ahead and seek professional help.
I took the sub out and checked the enclosure and it seemed fine. so I powered the sub up a little and I could here the rattle coming from one of the two voice coils. the sub is shot. so i'll just need to get another one but I ant an amp that has an equal amount of power this time so I can get the volume I want without the clipping. any amp suggestions around 1500watts rms?
thanks!
thanks!
thanks!
thanks!
if that is the case, you could replace or recone it....
-Tyler
gqdabien
Jul 22, 2015 10:30 PM
TheTripleC
Jan 4, 2015 06:46 PM
ScionTcGirl562
32
Mar 8, 2005 06:16 PM
