butt connectors?
Old May 19, 2004 | 12:14 AM
JDMbB's Avatar
Default butt connectors?
are butt connectors those thing on the end of thw wire where you can just plug it in and un plug it? does anyone know the size that would fit most switches?
thanks in advance
Old May 19, 2004 | 12:28 AM
chadfo's Avatar
This is a butt connector. It's used to connect two wires together in a butted fashion. Once they are crimped they do not come apart. I think what you are looking for is a disconnect
Old May 19, 2004 | 12:43 AM
JDMbB's Avatar
yea thats it, a disconnect. does anyone know a size or sumthin that would work? cause that woudl really help makin my light installs alot easier
thanks
Old May 19, 2004 | 12:56 AM
windowtint's Avatar
No, butt connectors cannot be plugged and unplugged. They are a "permanent" crimped connection.
you are thinking of either BULLET CONNECTORS or SPADE CONNECTORS (a spade connector is the red one posted above)
Old May 19, 2004 | 01:05 AM
dgHotLava's Avatar
the disconnects are generally two sizes 1/4" wide or 1/8" wide. (thats for the metal part that you see above)
there are different colors for the different size wire that the disconnect is to be attached to (crimp-on)
red - 18-20 ga. wire (really small wires)
blue - 14 - 16 ga. wire
yellow - 10 - 12 ga. wire (bigger wires)
then there is big red and big blue increasing in wire size
if you need more than this you should go see them in person....
Old May 19, 2004 | 02:50 AM
JDMbB's Avatar
thanks alot for your help. i think im gonna go to radio shack and see wat they gots over there.
prescottn
Oct 8, 2015 05:31 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
alias55
Scion tC 1G ICE & Interior
Sep 22, 2015 07:50 PM
Btp907
Sep 15, 2015 02:54 AM
