car alarm.. need info
hey guys, I was wondering does anybody know what kind of car alarms have the sensor where if you just touch the car the alarm goes off? or is that impossible? so far I'm either going to go with a viper or compustar or maybe a clifford alarm if I can't find one like the one I'm describing..
you probablly won't find a sensor that will do what you want. most all alarms have a (-) negative input for extra add-on sensors. plus if there was such a sensor you would have false alarms when it raines, leaves fall, and bird poop. your alarm is designed to protect the contents inside your vehicle.
as for brands, viper and clifford are the same company, they make good alarms. Audiovox/Prestige make really good alarms also. I'm not a fan of the Compustar alarms, but it's all up to you.
what would you suggest violent b? i wanted to get a compustar alarm but theres no dealership around here to install it for me.. so i might just go for a clifford or viper.
Originally Posted by mowmow
I have clifford and like it a lot all the bells and whistles installed.
doin't do viper, cheaper quality
if you have $$do Avanguard 5 or if 5.5 is out get that one.
same quality, has been for a long time.
both are top notch.
you can get a radar/motion sensor (might need two) if you walk close enough to the car it will go off.
or you can just turn the sensitivity up on the shock sensor.
but every gust of wind will set it off...
both are top notch.
don't beleive the hype ... dei and clifford are the same as viper , stinger hornet kxp , esp , damn near all alarms ... if they are made overseas , "designed in usa" they come off the same factory lines using the same vendors ...
but there are some diffrences ,, some have better switches and or remotes or horns ... but the same thought goes in to them ... very rarely will a car alarm unit (the brain , go bad .. if it does it usually has to do with installation .... the remotes are not figured in this ... users drop throw get wet remotes all the time that is not counted in the alarm ...
but to answer the question ... there is alarms with "touch sence" NCS A-100 has it plus "RIM GAURD" and "CAR JACK MODE " . let me know .... if that is something you are looking for ....
what company has that feature? website?
fluxingnation
Dec 26, 2014 04:28 PM
