Cathode installation question
Old Jun 2, 2005 | 07:42 AM
Grime's Avatar
Default Cathode installation question
Ok here is my plan, I am a total noobie when it comes to this wiring stuff, so I would appreciate input on if it would work on not:
I plan on buying a Cathode music interface (http://www.oznium.com/cathode-music) and using it to power FOUR 4" cathodes (http://www.oznium.com/cathode-kit-4), two under each side. I do not care about a switch or anything, I want it to be powered all the time because I figure I can control the lights simply with my sterero volume. But I plan on simply cutting the wire for the cigarrete lighter, twisting its two ends with the wire to the music interface, and taping it back up. Doing the same with the ground. Then the cathodes should easily run off the interface. But before I go in and start cutting, I wanted to know if this would work. And if I could still run things, like a phone charged, off the cigarette lighter. Any input would be greatly appreciated! Thanks.
Old Jun 2, 2005 | 10:34 AM
chadfo's Avatar
Don't cut the wires. Get wire taps.
Old Jun 2, 2005 | 02:30 PM
GT's Avatar
GT
http://www.radioshack.com/product.as...5Fid=64%2D3140
Old Jun 2, 2005 | 03:02 PM
XBman's Avatar
also it might be a good idea to wire them to a switch so if you are driving down the road and mr cop sees u...
Old Jun 2, 2005 | 03:41 PM
chadfo's Avatar
Good link GT. I've found 3M taps at my local Wal-Mart that are about that price or cheaper and have the double blade for a better connection.
Old Jun 2, 2005 | 03:53 PM
GT's Avatar
GT
Hrm, I'll look at those tonight chad.
I'll be doing this install tonight on my xB, so I'll post pics of the entire process, assuming all goes well.
Think I'm gonna go with a nuclear power theme with mine, call it the nukeBox.
Old Jun 2, 2005 | 04:02 PM
squirrel's Avatar
Get "T" taps and wire that way. Also, as previously posted, wire in a switch. Once your xB hits the street, a police oficer can ticket you for the underbody lighting. You can have them on if you are legally parked, just not while driving in the lovely Republic of CA.
Old Jun 3, 2005 | 03:48 AM
Grime's Avatar
See, the neons I have now are setup to when the music is at a certain level, they pulse. So whenever I see a cop, I just turn the music down (another good thing to do around police) and the lights go off.
Old Jun 4, 2005 | 01:10 AM
Oznium_com's Avatar
The music interface has an off switch on it.
Old Jun 4, 2005 | 02:37 PM
Max2k's Avatar
Don't just twist and tape your wires. You're asking for a short or electrical failure down the road.
Old Jun 4, 2005 | 04:47 PM
Grime's Avatar
yeah I ended up buying these: http://www.radioshack.com/product.as...5Fid=64%2D3140. They look pretty useful.
Now another noobie question: Would it be a good idea to tap into the ground wire also, or just make a new ground?
Old Jun 4, 2005 | 05:42 PM
Max2k's Avatar
Either way, it doesn't really matter if you're just running some 4" cathodes.
wiltonhall
Jun 23, 2025 10:09 PM
TotalChaos
13
Feb 4, 2015 10:24 PM
randode
44
Jun 29, 2004 04:19 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
BlueBox
9
Sep 25, 2003 04:36 PM
