Cold cathode woes...
Ok, I'll admit I'm an idiot, I don't know anything about wiring... so I hooked up a pair of cold cathodes (the kind meant for a pc), by utilizing randodes posts and the "interior lighting for >20" thread. I thought it was all well and good until I turned my headlights on, at which point, the cold cathodes went out! I could see how if they ONLY worked when my lights went on, but if they DONT work when its dark outside and I need my headlights on, then what's the point!
So anyways, I have them plugged into the little white plastic power source thingy that you get from reaching behind the dash between the two seats. There are four holes in it, only two of which have metal on the inside, the first one and the third one. I was using the first one which again, works on with the headlights off. I tried the other one, and it doesnt work in any case. I'm assuming the other 2 holes dont do anything since there is nothing conductive inside....
Any help would be appreciated.
one of the easiest power line to tap into is the green wire from the gear box... i recommend getting a light switch with the inverter.
The cathodes will stay on when u turn on ur amber/headlights..and u get the option of turning it off when u don't want the glare while driving.
good luck
good luck
Originally Posted by showpaojoe
You gotta tap into the all green one
And that's where I tapped into also. Why? Cuz Randode says to in his instructions for his kit.
THANKS RANDODE!
airmankevin1
Nov 17, 2015 05:44 AM
vi3tb0i09
Sep 23, 2015 08:32 PM
