Day Time Running Lights for the xB
Old Jan 22, 2004 | 06:29 PM
scionspecialistvegas's Avatar
DISCLAIMER:THIS A GUIDELINE FOR DIYRS ALL WIRES MUST BE METERED AND CHECKED FOR PROPER OUTPUT BEFORE INSTALLATION. NOT RESPONIBLES FOR ANYONE WORK BUT OWN.
supplies: (2)spdt relays 6ft of 16awg wire, ( female terminal ends(speakers females) soldering iron or crimpers.4 blue butt connectors.
1. Locate ignition wire, splice into 12 ignition source.
2. take wire from ign and input to pin#86 on first relay
3. pin 85 is hooked to ground
4. pin30 get a constant 12v,not switched12v from the ign.
5. pin 87 goes to the parking lights or fog lights.
Now if we want to add headlights to day time running lights
1. pin 86 to is jumpered from from pin 87 of first relay
2. pin 85 and pin 30 are tied to ground
3. pin 87 is spliced into light wire.
if you just want headlights for your running lights
1.pin 86 is spliced into into ignition 12v source
2. pin 85 and 30 to ground
3. pin 87 to to head lights,
All the wires needed can be found at steerring column. Two screws hold he plastic cover inplace. You need to turn the steering wheel to access both screws. Tap on plastic to get the bottom of the column to come down. iF YOU HAVE PROBLEMS YOU CAN CALL ME 702 250 8286, I CAN PROBABLY WALK YOU THROUGH IT, OR I CAN MAKE A PREWIRED KIT. BILL
Old Jan 22, 2004 | 06:45 PM
raiden1200's Avatar
Bill Rocks !:twisted:
Old Jan 22, 2004 | 06:49 PM
FOR YOU XB AND XA OWNER WHO, JUST WANT A KILL SWITCH WITHOUT ALARM LET E KNOW. I HAVE A RELAY CONFIG. FOR THAT ALSO. BILL
Old Jan 22, 2004 | 10:46 PM
yanges's Avatar
Originally Posted by scionspecialistvegas
some people just prefer the light to come on and turn off automatic with turn of the key. I might have surprise for you in a couple if days. Bill
Old Jan 22, 2004 | 11:36 PM
TheRedBox's Avatar
Dude your pimp.
Pimp just like the shoes with the goldfish in 'em.
Old Apr 11, 2004 | 10:23 PM
Kib's Avatar
Kib
Default What about DRL from Canada?
I wonder if you could purchase/use some kind of DRL module from Canada?
I did that for a Mazda Miata, our friends in Canada must have DRL's, so rather than goofing around with some wiring hack, took a trip to Vancouver and had them install the DRL module. It was essentially a plug & play.
I know they don't sell xA' or XB's up there, but how about a Echo DRL mod???
Anyone from the Great North know anything ?????
Thanks in advance !
Old Apr 13, 2004 | 02:36 PM
Kib's Avatar
Kib
Default Canadian DRL's
Got the following email, to answer my own question:
I DID FIND A RUNNING LIGHT MODULE FOR
THE ECHO. IT IS 82642-52020 AND IT SELLS
FOR 249.00 PLUS TAX FOR A TOTAL OF
$286.35 CANADIAN. I DO NOT KNOW IF THE
WIRING IS ALL THERE, BECAUSE I DO NOT
HAVE ANY WIRING DIAGRAMS FOR THE
SCION. IN THE ECHO IT MOUNTS IN BEHIND
THE HEATER CONTROLS. HOPE THIS HELPS
THANKS
STEVE CHRISTIE
PARTS MANAGER
EASTWAY TOYOTA
(BTW - Eastway Toyota is located in Windsor, Ontario)
Comment - Ouch, $250 is kinda steep. It would be interesting to attempt a part number cross-reference, as well as checking the wiring diagrams.
Thanks to Steve @ Eastway for his assistance.
Old May 21, 2004 | 10:19 PM
TheScionicMan's Avatar
A cheapie setup on eBay:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33710
Unichip_jack
Scion tC 2G Forced Induction
Dec 4, 2014 02:17 AM
Pirate183
Nov 29, 2014 07:37 PM
Unichip_jack
Nov 25, 2014 07:41 PM
