dented kappa perfect midrange...
Old Jan 13, 2005 | 01:21 AM
tbone587's Avatar
Default dented kappa perfect midrange...
I dont know how it happened, but right in the center my infinity kappa perfect door speaker, has an indent in it.. Is this going to effect anything?
Old Jan 13, 2005 | 04:24 AM
Reign_Man's Avatar
well yea...sound quality id say will be affected. assuming thats all the damage there is. take the speaker out and make sure nothing else was hurt
Old Jan 13, 2005 | 04:30 AM
tbone587's Avatar
how is the send quality going to get affected? Is there anyway to get the little dent to pop out?
Old Jan 13, 2005 | 05:11 AM
ScottsdaleTC's Avatar
The “Dust Dome” covers up the voice coil and pole piece area, the inner workings of the motor structure. After the voice coil and the leads from the terminals are soldered the dome is the last piece to be glued to the speaker cone. It is partly cosmetic to cover up the inner motor. Secondly the dome now becomes one with the cones surface in compressing air (sound) when played. If the dents are small and there are no holes going all the way through the cone, you will not notice any change in sound.
If the dome is not “creased” and has soft dents then you can use a small strip of tape. Gently lay the tape on the dome and give it a quick pull, this should have enough pressure to cause “soft domes” to pop back out. If the dome is “creased” or “hard plastics/metals” it will not work. It is best to just leave it as is and only you will know it is there.
Old Jan 15, 2005 | 03:43 PM
Sciond's Avatar
good advice^^^^^^^^^
airmankevin1
Nov 17, 2015 05:44 AM
Schmohey
Oct 4, 2015 02:53 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
