Disortion with Stock HU and Upgraded Speakers
Originally Posted by Chiguy_2002
You can start off with an amp, and use the Subplug (probably Subplug 4 which allows you to run a sub amp and a 4-ch amp, the Subplug 2 allows you to add a sub/amp and use factory power for speakers). Turn the bass and treble for the headunit down to 0 or lower. Don't turn up the gain on the amp too much either. That should help improve sound. Adding a better head unit will help, but there are things you can do to get decent sound of the stock head unit.
Besides, with the stock head unit, it's a little more stealthy.
What I really want is iPod integration in my car (not just the AUX in). I wish I had the money to buy the iPod-ready Scion-Pioneer set, a 3Sixty or other EQ eliminator, amp, etc... but I might as well just get a better head unit for a cheaper price and forgo the extra EQ box.
I'm sure I could eliminate the distortion problems by simply adding an amp to my current setup but then I'm not all that 100% satisfied with any of the SSP settings and how they sound in my car either. My last car had my BA speaker set driven by an Eclipse unit alone and they sounded much better.
I'll be heading off to my local friendly independent ICE installer to see what my options are keeping cost and ultimately SQ in mind.
Thanks for the information, it's all very helpful!
If you want to keep it stealthy then the Cleansweep is my suggestion. It has an auxillary input for your iPod and IIRC JL also makes an adaptor for multiple auxillary sources. I also like the idea of keeping it stealthy. To me that sounds like the best bet for your needs at this point. Scour, ebay and I bet you find one for a reasonable price. Mark
^^^ hey!!! I didn't realize you were from Carbondale...
I suggest upgrading your HU first to get rid of the DSP that's built into the factory deck... then if you feel the need, add an amplifier to the aftermarket speakers...
I will definately be replacing the HU very soon. I'd really like to get the Alpine double-DIN (DVD playback, touchscreen, iPod & BT ready) but that depends on how cheap I can manage to get it. Otherwise, the CDA-9857 looks good for audio-only.
If the new HU still doesn't provide enough power then I'll consider buying a 4ch amp.
IMHO, an aftermarket HU w/iPod integration is the best value.
I have the Scion iPod HU and am considering replacing it with an Alpine or Eclipse. The cost of an additional processor just to keep the stock HU seems excessive. The stock xB system is not that integrated nor aftermarket prohibitive.
Also, iPod integration is not just an "aux in" plug or connector IMO. Can you access and control your pod from the HU? Does it charge it? Is track info available on the HU display?
An aux in only solution does not measure up in this day and age. Perhaps when the 3G pods just came out. We had to fabricate dock connector to RCA cables back then. Those are some of the smallest wires I have ever worked with!
My distortion problems are finally solved.
Today I replaced my OEM HU with a Alpine CDA-9857, and added a JL Audio e4300 4 channel amplifier to power my Boston speakers.
OH. MY. GAWD.
I couldn't believe my ears. This setup sounds amazing. I honestly could not ask for much more in sound quality as far as my ears are concerned. The only problem now is rattle/vibration caused by the lack of sound deadener when the system is cranked up VERY LOUD, but even that is not a big issue for me because I'll never run it that loud normally. I'll eventually put in some RAAMmat when I have lots of money to burn (thanks TerribleTed for your suggestion).
The Alpine HU has iPod integration built-in. After spending about 10 minutes learning the buttons the interface isn't too bad, but I learned that even with Direct (Percentage) Search, navigating hundreds of albums, artists or songs is difficult. The solution is to use small playlists to eliminate the 90% of music I don't listen to very often and sync up my iPod when I make changes. Not a big deal. The iPod fits great in the left side of the glove box.
I've ordered a steering wheel control interface which I will install next week when it arrives. I miss the remote volume buttons already, unfortunately... but the benefit outweighs this minor inconvenience.
Before, I assumed my speakers were bad because they were old and sounded so terrible. Now, the speakers sound better than they did in my old car powered off their own amp.
Thanks everyone for your input (especially tanakasan and SCI_TC_GUY). You guys rock!
OH. MY. GAWD.
anti_virus347
May 28, 2015 06:01 AM
anti_virus347
Apr 3, 2015 05:17 PM
clickclickw00t
Feb 18, 2015 08:57 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
