double din hu?
Old Aug 2, 2004 | 07:06 PM
trini_ef_racer's Avatar
Default double din hu?
Ok i know that i saw the eclipse one in someones car but , is that the only one that will fit or are there others?when i went to crutchfield it said none of them would fit. thanks
Old Aug 2, 2004 | 07:18 PM
Giravani's Avatar
Do a search it's already been discussed in great length. There are more than just the Eclipse HU that fit.
Old Aug 2, 2004 | 07:28 PM
naoki's Avatar
Crutchfield will give you invalid results because the HU space in the Scion is actually a little bit larger than the average double-din HU. So, I would believe most double-dins would fit.
In terms of something that is a lot like the eclipse (meaning Double-Din with a built in screen): the only other one that I know of is the Kenwood-ddx7015, which I am looking into getting myself. Great system and can be had for less than the Eclipse as far as I know.
The eclipse you were looking at is available in 2 or 3 models though, with or without NAV and with or without a hard drive (I believe). I'm not sure how they compare to the kenwood in terms of features.
Old Aug 2, 2004 | 07:36 PM
Enkidu's Avatar
check the link in my signature. got the kenwood for 950 on ebay.
Old Aug 2, 2004 | 07:39 PM
naoki's Avatar
yah I knew about ebay... shh.... I don't need bid competitors!
j/k... they are mostly "buy it now" anyways.
Old Aug 2, 2004 | 10:00 PM
TheIcon's Avatar
Default Re: double din hu?
As was stated above the reason crutchfield says the double din doesn't fit is because the opening in the dash is about 1/2 inch wider on the left and right side of the receiver. A simple fix is to cut some plexi-glass and put it on both sides. This is what I did with my Kenwood ddx7015. By the way the person looking at the Kenwood. You will love it. (Im still trying to figure out all the buttons and fancy stuff )
Old Aug 3, 2004 | 12:49 AM
cme42ns's Avatar
A little fiberglass/bondo/etc. and paint.......voila!
Thanks to Unique Car Audio in Gilbert, AZ.
Old Aug 4, 2004 | 04:48 PM
TheBigGuyRy's Avatar
Enkidu, your sub install is awesome. Did I miss a post on this earlier or have you just not talked about it very much?
That's exactly what I wanted to do with mine.
Tell me about it if you haven't posted on it yet.
Old Aug 6, 2004 | 07:10 PM
Bushido's Avatar
Any suggestion on a double din unit that isn't an LCD nav unit? It seems like it's either a choice to go hi-tech at $1000+ or have the single din unit with an empty tray underneath (or a component stack like the cd receiver / digital media controller combo above). Seems like all of the double din units out there are pretty low-tech.
Pioneer has the Pioneer FH-P5000MP w/ mp3, aux input, "future-proof" input, RCA outs, CD changer and XM-ready capability. I haven't seen one in person though, so any comments are welcome from those who have.
What is the depth of the Scion tC opening? I know some shims have to be rigged on the width, but is the cavity unusually shallow? The Pioneer unit is 181mm (around 7") deep including the faceplate.
Of course any other suggestions for decent double din units that have actually been successfully installed in a tC would be greatly appreciated.
B.
Old Aug 6, 2004 | 08:35 PM
eugovector's Avatar
Go with 1DIN and a pocket. It will cost less for what you get and you will have room to upgrade later. Down the road, you might want to install an LCD screen like the ones at www.mp3playerstore.com or install an HD based mp3 system or a carputer. The short of it is, don't use 2 dins just to fill them up. You are only shooting yourself in the foot.
B.
Old Aug 7, 2004 | 02:11 AM
You'll want to use both DIN openings if you want to create a stock look and if you happen to hate pop out screens like I do.
I'll probably be custom fitting a 7 inch lilliput VGA touchscreen pretty soon... i'll post a how to on it... Shouldn't be too difficult.
Bushido, as far as the actually depth of the hole that the HU sits in (if that's what you're talking about) It's extremely deep. I don't have any exact measurements on the depth (the stock radio is about 5 inches high and about 8 inches wide), though I can tell you that you probably won't run into any problems fitting anything in there once you remove the stock HU.
Take a look for yourself though... pop off the bottom silver part of the dash and then the top silver part. It's extremely easy to get off and put back on.
Old Aug 7, 2004 | 07:09 AM
Bushido's Avatar
I agree this is the best way but my wife wants a "stock" look for her tC and doesn't like the cubby look of a single din adapter. Most of the double dins I've seen pictures of are just butt ugly with no advanced features, We'll just keep plugging along in the meantime.
Thanks,
B.
Old Aug 7, 2004 | 02:22 PM
naoki's Avatar
I'm totally with you, I hate single-din head units if there is space for a double-din.
Old Aug 7, 2004 | 07:36 PM
gobblez's Avatar
Default double din
i like that kenwood one with the screen built right in. thats basically what i want, but there is one more feature i want that it doesn't have, navigation. i've seen some units that have dvd/mp3/cd/nav but are single din with a fold out screen. fold out screens don't look like they belong to me... can anyone help?
Old Aug 8, 2004 | 12:02 PM
Bushido's Avatar
Check out the Eclipse AVN2454. Here's a good thread: https://www.scionlife.com/forums/viewtopic.php?t=20902 See here for lazyleg's tC install: http://f2.pg.photos.yahoo.com/ph/sss...bum?.dir=/be3c
Looks totally stock, $$$$$
B.
oldcodger
Scion tC 1G ICE & Interior
Dec 24, 2015 09:46 PM
mischman
Sep 15, 2015 03:38 PM
JZA70
Sep 12, 2015 09:44 PM
kslim619
Aug 18, 2015 01:22 PM
DJrepresent
Aug 12, 2015 06:37 PM
