electrical provblems please help.
my positive and negative leads for my amp got crossed and now i have no power to my radio, alos my tach needle will not return to zero when i shut the car off, and when i turn it back on the clock is rest to 1:00 and the keyless entry stopped working, one last thing i noticed when taking my girlfriend home was that the dome light is also not working i checked all of the fuses and none of them are broken at least where i check by the fuse block on the left behind the ciggarette carton holder..... its a nightmare please help... what could have happend?Is there any other fuse block that i don't know about??
Is your power wire for the amp fused?! The fuse should have blown before any problems occur. If it is fused, what amperage, and what gauge wire are you using?
As far as solving the problem at hand, do check the fuses under the hood. Also, disconnect the battery for 20 - 30 minutes. See if that solves any problems.
drgonzo92
14
Apr 24, 2019 07:27 PM
Wrencher
Jul 29, 2015 01:38 PM
