factory speaker replacement
Old Mar 21, 2005 | 06:42 PM
bigmike's Avatar
Default factory speaker replacement
has anybody replaced the factory speakers yet? if so was it easy to DIY. and what speakers did you use ? i beleive it is 5 1/2 and 6 1/2 speaker sizes. please help !!!
Old Apr 8, 2005 | 02:31 AM
sar4scion's Avatar
mike check out the tech section in scionlife I (dims) did it my self and not too bad of a project but you do need a buddy and the proper spacers and the harnesses oh and it's 6.5 speakers front and back I used polk rear and infinity front clean sound and not too expensive . hit me back if you need more info Stan
Old Feb 28, 2007 | 01:22 AM
stonecoldnimrod's Avatar
for christ sakes last weekend i took off my door panel so i could replace my factory speakers with pioneer 6 1/2 4 ways.
1- i needed brackes on the front speakers to properly install my speakers. otherwise there will be terrible gaps beterrn the speaker and the holes - not to mention drilling 4 custom holes into the door.
2 - after i plugged in the speaker into the door and added the panel back on... somehow the factory speaker sounded louder than the newer one i purchased. must be the casing the speaker is built with - gives it more bass?
so i found that crutchfield sells brackets for the front speakers to hold it in place with original holes. i was too frustrated to even try looking at the back speakers cause the wind knocked over my frint door panel andc scratched the silver pieces (made me go to pep boys to buy some supplies to sand the silver pieces and paint them red).
do i need brackets for the back speakers?
how are they mounted?
can the stock unit handle 260 watt four way speakers?
did the factory speakers sound louder because of the housing the speaker is built onto?
... thanks for the help.
Old Feb 28, 2007 | 01:21 PM
UV7's Avatar
UV7
Yes, you do need adapters to install speakers in the doors as well as for the speakers in the rear of the vehicle. You can purchase adapters for all the speakers from Crutchfield, Elemental Designs, etc., or just make your own.
Not really. The factory stereo system is designed with a digital signal processor that is programmed optimally for the factory speakers. This DSP often makes aftermarket speakers sound crappy in comparison. The best solution is to replace the HU. I know others will flame me for saying this, but the factory HU is severely inferior to many aftermarket choices on the market today. Since you've gone to the trouble of replacing your speakers, you may as well make them sound their best with the aftermarket HU of your choice.
Old Mar 1, 2007 | 02:17 AM
thanks for that advice. i already purchased the pioneer in dash dvd player and when that's installed i'll drop the 4 ways.
Old Mar 1, 2007 | 11:07 PM
Iride_xB04's Avatar
wait what are the speakers sizes for front and back?
and how cheap can I replace the speakers with
Old Mar 2, 2007 | 12:53 AM
i bought 4 pioneer 6 1/2 4way speakers off of ebay for about 45 dollars a pair plus shipping.
Old Mar 4, 2007 | 11:42 PM
PaRaGoNViCtiM's Avatar
The SEARCH button is your friend!
https://www.scionlife.com/forums/vie...=speaker+sizes
Old Mar 6, 2007 | 08:38 PM
Chiguy_2002's Avatar
Aftermarket speakers will usually sound best when amplified. The factory deck does not put out much power, especially to push aftermarket speakers. If you add a amp to the factory deck, it will sound better, though an aftermarket deck will be even better. The factory speakers do not require that much power to drive them, so they sound fine with the factory deck.
Old Mar 7, 2007 | 07:47 AM
liucid's Avatar
yeah, but if you're just gonna replace them with entry level stuff they'll be fine. the new speakers will have a better sensitivity rating as well, so in all actuality it'll probably be louder.
blh72
Scion xD Wheel & Tire
Feb 2, 2015 12:36 AM
torranosaurus
Jan 28, 2015 04:53 AM
lunchbx05
Dec 29, 2014 07:53 PM
cwong1001
Dec 3, 2014 03:30 AM
shaefner
Oct 8, 2003 02:48 PM
