Feeding wires thru the Fire Wall
Old May 7, 2005 | 06:22 PM
RFX's Avatar
RFX
Default Feeding wires thru the Fire Wall
I'm installing aftermarket foglights and I can't figure out how to get the wires thru the firewall to the switch. The two holes i found are for the existing wiring in the car, but I can't get the wires thru the rubber. Is there another way around????
Old May 7, 2005 | 06:24 PM
dgHotLava's Avatar
moved...
Old May 7, 2005 | 06:28 PM
neckbonenick's Avatar
use a knife to cut a little slit in the boot that covers the factory wiring harness. Then tape your wire to a long screwdriver and push it throgh to the other side.
Old May 7, 2005 | 06:39 PM
M-Flo's Avatar
Use a wire coat hanger instead. Much easier to fish wires through that boot.
Old May 7, 2005 | 06:57 PM
crayonBOX's Avatar
^agreed on the coat hangar. you can pass it thru the grommet by making a slit in it/w a knife, just keep it a little smaller than you need; rubber stretches
XirtaXa
24
Jan 14, 2025 03:49 PM
ScionLife Editor
Mar 21, 2015 03:10 PM
XB06
Feb 16, 2015 06:03 PM
TCnewguy
Feb 16, 2015 03:50 AM
Scion_707
Dec 31, 2014 03:28 AM
