few questions on wiring cathodes
Old Jun 22, 2007 | 04:49 PM
wolfsocr20's Avatar
Default few questions on wiring cathodes
my cathodes should be in any day now and when i wire them to the fuse box using an add a circuit i was wondering what size fuse do i need to put in the fuse holder for the cathodes.(not the fuse that goes in the add a circuit.) and where is a good place to get power for them. it don't really matter if it is a spot that always has power going to it or not.
Old Jun 22, 2007 | 06:54 PM
ShaunMiller's Avatar
Check oznium.com for installation tricks, lot of good info on there.
Old Jun 22, 2007 | 07:10 PM
kewlbox's Avatar
I think i put a 5 amp fuse in mine. Don't remember which one i used but mine are powered all the time. I just used a tester to find one that is powered without the key on, It might even been one that was empty from the factory.
Old Jun 23, 2007 | 02:13 AM
SanchezHacker's Avatar
I have a 5amp fuse in mine as well, but I also have some other things being powered off of the same line and I haven't blown it yet. I think you can go as low as 2 or 3 amp fuses, depending on what cathodes you are using. I know some use more power than others.
Old Jun 23, 2007 | 02:15 AM
esisso's Avatar
i have a tc...blue cathodes....3 amp fuse
Old Jun 23, 2007 | 03:09 AM
LLcoolTREY's Avatar
the bottom right fuse is powered all the time, thats the 1 i used
Old Jun 23, 2007 | 03:20 AM
Metro273's Avatar
Default Re: few questions on wiring cathodes
Randode's kit takes out all of the guess work, just plug-n-play.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
randode
44
Jun 29, 2004 04:19 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
