fiberglass sub enclosure inside spare tire.
Old Jun 21, 2007 | 08:18 PM
nikbrewer's Avatar
Default fiberglass sub enclosure inside spare tire.
well, I am almost done with my second speaker box for my xb. My first in on ebay, replaced back 2 storage compartment, and held (2) 6.5" subs, sounded really good (check it out).
I wanted to do something different though. SO looking at the back, i noticed how much space was wasted cause the spare tire and how it was mounted. SO, i cut out the center of the foam that holds the spare so it can be laid in the upside down.
next i constructed a fiberglass box to fit in the spare. I did this by cuttng a mdf ring that just fit inside the lip of the spare, and was about a 1" thick ring. next i covered the whole tire and wheel in duck tape. then sparyed it with non stick cooking spray. I also cut a small circle to go over where the lug holes are. Next i began adding resin and fiberglass until i had a bowl that was solid and about a 1/4 thick, maybe a lil more of fiberglass. I then drilled a hole in the bottom that lined up with a lug hole inthe wheel, and resined in some speaker wire. I then added a top to the bowl, with the proper cutout size for the sub ( a shollow mount elemental designs 10"). i then coated the inside and our of the box with rubberized truck liner.
after doing the math, after speaker displacement, the box has about .33 cubit feet of air space. It sounds really good to. I need to build a cover for it though, as its about 1/2" from fitting under the stock cover, i could probally make a version 2.0 fit under there. But i am building an amp rack that will replace the stock storage are, and it will have a nice cover over it all.
all and all, it sounds really good, and uses no space in the car. This would work great on the xa too, since it uses the same spare, and has even less hatch room.
I will post pics when ever i get home
Old Jun 23, 2007 | 01:32 AM
HondAudio's Avatar
I can't wait to see it
Old Jun 23, 2007 | 05:01 PM
nikbrewer's Avatar
i will be posting pics today
Old Jun 24, 2007 | 12:20 AM
nikbrewer's Avatar
wel, i have som epics of my speaker box, but how do i post pics? will someone host them for me?[/img]
Old Jun 24, 2007 | 12:45 AM
nikbrewer's Avatar
well, here are the pics of my speaker box
installed in tire
close up
side view
back view
hopefully i will finish the whole thing next week when i get some color matched carpet. it sounds really good and doesent move at all
Old Jul 4, 2007 | 08:30 AM
HondAudio's Avatar
Looks like you forgot to mask off your spare when you were fiberglassing :o
Old Jul 4, 2007 | 05:29 PM
brambling's Avatar
I like it.
Can you put the cover back on, or does it ruin the subwoofer effect?
Old Jul 5, 2007 | 05:29 AM
Blacklisted's Avatar
i really like it.
how loud is it?
Old Jul 5, 2007 | 01:26 PM
nikbrewer's Avatar
it sounds really good. Goes pretty load too, but bottoms out at max. I might have an air leak. I did mask the spare, thats just resin dust, it all wipes off. I got the cover and amp rack done last weekend, so ill post pics later today. If anyone is interested in one of these, i would make one or sell this one, as I already have ideas on how to make a betterone
Old Jul 5, 2007 | 01:43 PM
CXT's Avatar
CXT
I would love one if you get it to work properly.
Old Jul 5, 2007 | 04:09 PM
nikbrewer's Avatar
i will send pics later. My coer replaces both rear covers, but looks stock. It allows you to keep you stock spare, with a small amount of the foam that holds the spare.
Old Jul 6, 2007 | 02:27 AM
nikbrewer's Avatar
well, here are the pics i promised. the only thing lacking is finishig the amp rack, which i dont have a amp for, so it might wait.
here is a pic of it finished and installed
this is a close up of the grill. It is a metal grill with speaker grill fabric to blask it out. I used a 12" so it would be easier to get the hole arounf the 10" sub
this is going to be the amp rack. I plan on putting i a fals ebottom that the tools will be under, and the amps on top. I will cut a window in to the cover, and put in a screen covered in speaker grill material so the amp can cool, but no one can peak in a see them
this shows that it is perfectly flush with the seats when they are laid down.
I am thinking of making a few more of these, so if you are interested PM me, or look at my other thread
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
rain7905643
Jun 13, 2018 05:29 AM
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
mcnick0495
Scion tC 2G ICE & Interior
Sep 8, 2015 02:58 PM
