Front seat swaps~??
Old Sep 11, 2012 | 11:44 PM
mattsthunderxb's Avatar
Default Front seat swaps~??
How hard is it to swap the front seats.....passenger over to driver's seat. My xb has 150K on it and the previous owner was a big, heavy dude, the drivers bottom seat cushion caves down at the front. Looking over there at that hardly used passenger seat - I'd like to swap them. Is possible, or nearly impossible?
New here, already used the site to swap out to some nice led taillights~!
Old Sep 12, 2012 | 02:23 AM
Vulkinator's Avatar
I have no experience with this but I believe that the levers to adjust the seat back would be on the wrong side of the seat.
Old Sep 12, 2012 | 07:11 AM
buickid's Avatar
The reclining mechanism would be on the wrong side, and the mounting pattern would be wrong. The easiest way might be to grab a seat from the junkyard and throw it in. Its pretty easy, 5 bolts and a plug if I recall correctly.
Old Sep 12, 2012 | 06:41 PM
Yes, was hoping someone had experience removing the lower cushion for a swap .
Maybe add a couple washers under the front bolts to tilt the whole seat back a bit...would that work? (I'm sliding off the crushed seat edge....or is this a engineering weak spot in the ergonomics of an XB?)
Running XBs are pretty scarce 'round here(Ohio farmlands) ....wrecked ones nonexistant~!)
Did a seat swap on my 91 VW Vanagon, 10 mins, no issues....but quickly saw the seatbelt mount & recline lever would make an XB less simple...so came to youse guys~!
Old Sep 12, 2012 | 07:41 PM
JIMXB's Avatar
Next option would to visit a car upholsterer to get a quote to replace top + bottom padding. Figure your qoute to be about 1 1/2 labor, plus materials.
You will need to have nimble fingers to do this yourself, for it is a tight fit gettting off + putting back the 2 pc covers + find the correct density foam + cut the foam correctly. But, may be easy getting the covers off since they are squashed.
Good Luck....
Old Sep 12, 2012 | 08:33 PM
Big_Jim's Avatar
Www.car-part.com or www.eBay.com
Car part searches junk yards. You may be able to find a yard by you that would even ship.
Old Oct 6, 2012 | 01:57 PM
DaWiz711's Avatar
I have also read that celica front seats line up/are easiest to mod to line up, but I haven't personally seen/done. It sure looks close though...
carid
Jan 22, 2015 12:49 PM
torranosaurus
Jan 3, 2015 03:06 PM
moontom
Dec 15, 2014 04:14 PM
avus
Dec 3, 2003 12:46 AM
TDogg490
Nov 27, 2003 11:37 PM
