gauges , turn signals , power windows , radio all inop
hello everyone. i was installing blitz supercharger(jdm version). while i was trying to get activation box to work i plugged a power wire from switch to fuse box and heard a pop like a fuse popping. looked the fuse is still good. now gauages ,t/s,p/w, and radio are all not working. anyone have the fix? i read other topics and tried all and nothing has changed.thanks anyone and everyone.
even if a fuse might look good.. it still has the possibility that it isn't.
check for continuity and replace if necessary... might want to look at the other fuses too.
Yea, give it a shot. Remember, just because the fuse looks fine, it still might be shorted.
I was replacing a dome bulb and I lost all of the things you described... it's a 10A. IIRC
thanks ; i will check again. i was in the process of pulling dash out because i figured i really screwed something up on the main fuse board. what a pain. i will check again. but the dome light works. could it still be that fuse?
check all fuse..like everbody is saying just cause it doesnt look blown it can be..also check the fuse under the hood..and if u got the service manual..check for any hiding fuses..i found one fuse hidin over by the glove box on accedient...
thank you everyone!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ok i am so relieved. ended up the green 40 amp fuse above mini fuse block under dash was blown. like everyone suggested it didnt look blown until taken out and opening up the cover. thanks
randomsuper
20
Jun 13, 2015 10:56 AM
minter66
Dec 15, 2014 01:45 PM
