having trouble charging a capacitor....
after trying to charge the cap the first time with out success, i discharged it and tried it for a second time....same result, with the third try i also had no success. i'm not sure what i'm doing wrong. this is the second time that i have ever used a cap, the first time was smooth and successful.
can any1 help?
try charging it using a lightbulb (brake, dome, whatever) or a standard test light.
- connect ground
- wire bulb inline on positive lead, hold to positive terminal until bulb goes out. you should be charged but check voltage using multimeter. if its not around 12v your cap is toast.
- connect ground
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
BlingSlade
Sep 5, 2015 08:52 AM
