Headlights & Foglights circuit diagram
HERE'S A SITE WHERE A GUY REWIRED HIS FOGLAMPS INDEPENDENT FROM THE PARKING LIGHTS...
HOPE THIS HELPS...
http://members.***.net/inazuma/fogs.htm
HOPE THIS HELPS...
Here is a site that has some OEM looking switches.
http://www.remingtoncoachcraft.com/p...hes/index.html
I been doing some thinking
all there is to do is find the cable that tell the fogs circuit that the headlights are on and feed the fogs circuit whit one of the parking lights so you can turn the fogs whitout the headlights been on ,right :?:
Originally Posted by sanders
i'm also interested... having a problem with my HIDs, as soon as i plug in the harnesses the lights turn on without the headlights switched on. i'd like to see a diagram as well... thanks.
u need to re-arrange the connectors that goes into the harness (before you hook up to oem headlight harness)
I did a little "research" today... The factory fogs run off a relay that is on left side of the fuse box. The relay plugs into the back of the second "appendage" down on the left.
Going into the front of the relay holder are 4 wires, in no particular order, Black and white, white and black, black, and Red.
I'm assuming that the black wire is from the ignition switch and the black/white is from the headlights. Can anyone shed some light on using what's there to be able to make the appropriate change to have power to the fogs when only the parking lights are on?
vi3tb0i09
Sep 23, 2015 08:32 PM
