Help me build an portable sub enclosure!
Old Apr 10, 2004 | 04:31 AM
mikochu's Avatar
Default Help me build an portable sub enclosure!
hey guys,
I want to build a sub enclosure that I can take out whenever I want. Kinda like the bazookas...but without the bazooka. I'm willing to build it myself, but I just need some professional directions. I don't want to t-tap wires or anything...
I'm guessing I need an amp, sub, wood, and whatever else...
Thanks
Old Apr 10, 2004 | 04:39 AM
macncheese's Avatar
Default Re: Help me build an portable sub enclosure!
Originally Posted by mikochu
hey guys,
Thanks
What kind of tools and skills do you have? How big are we talking about? 8", 10", 12", 15", 18" ?
Cheese
Old Apr 10, 2004 | 04:59 AM
mikochu's Avatar
an 8" or 10" should suffice... I personally have a drill, dremel, hammer, screw drivers...and hands... I have fisher price soldering skills (can't solder tiny points). I have a friend who can help me if I need help... I'm looking for xA/xB specifics...outputs, portability...etc...
Old Apr 10, 2004 | 09:44 AM
KingLou's Avatar
Well, no matter what you do, you're going to have to tap some wires to get a signal to your amp. There's no getting around that cause your stock head-unit doesn't have RCA pre-outs. If you get an aftermarket head unit......then that's a different story.
As far as box and subs go........I'd say look for a 10".......and do some research into subwoofers that perform well in small sealed enclosures. You can build a small sealed box that is basically just a cube, and slap some heavy duty velcrow on the bottom (like I did to my box).....and viola......it's not moving anywhere while you drive around, but if you wan it out, you can take it out.
For example. If you want nice, clean, versatile bass.......a setup like this might work for you:
Infinity Kappa Perfect 10.1d 10" dual 4 ohm voice coil subwoofer: http://cgi.ebay.com/ws/eBayISAPI.dll...090120949&rd=1
Hifonics Brutus BX500d D class sub, which will run your sub (properly bridged and wired) at 250 watts: http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
...or if you want a little more power.....
Hifonics Brutus BX1000d D class sub, which will run your sub at 700 watts: http://cgi.ebay.com/ws/eBayISAPI.dll...090597091&rd=1
And you can put this speaker in a tiny sealed box of 0.6 cu. feet. Building such a box shouldn't be hard. You should buy 3/4" mdf wood.
KiL
Old Apr 10, 2004 | 02:12 PM
macncheese's Avatar
Well you're going to need a saw to cut the wood Despite what everyone says around here, don't use MDF, especially if you want to take it in and out often (MDF is HEAVY!). Use Baltic Birch or marine grade plywood for the enclosure. You'll pay a bit more for it but your enclosure will sound a lot better and weigh a lot less.
The smallest enclosure you can make is probably a sealed enclosure. Polyfill will let you undersize the cabinet a bit as well. I have some little noname Aluminum Cone DVC 8"s if you want something to experiment with, $10 + shipping... Let me know
Cheese
eujin
Feb 23, 2016 01:18 AM
EVILDAVE
Sep 15, 2015 06:54 AM
javio24
Aug 23, 2015 01:07 AM
umnitza
Aug 21, 2015 12:35 AM
