HELP Please !!! any help replacing my Scion Tc Head unit !
What youre asking for isn't clear... but I can say you should probably just take it somewhere and get it done. Better to spend $100 to get it done right than fry something that cost twice as much and leave you still without the new unit installed.
I have done a couple head unit installs. Even in my current car (18 years old) it was easy. Everything and I mean EVERYHTING is color coded. Just get the mounting bracket for the tC (It has been out for a year I would think SOMEONE would make one) and the wiring harness. In many cases you do not even have to cut any wires. Just connect the wiring harness to the OEM plug and plug the HU into the wiring harness and viola! Stuff it all in there and you are done. Usually the hardest part is ripping apart your console. But most Jap cars just pull apart with some force.
Anyway, hope this helps.
if you need to mess with the wires (its very very easy) that is if you cant find an aftermarket harness (since the car is so new) then heres something that might help.
wire name/description
wire color
GR (ground)
brown
ACC (ignition ACC)
gray
B+ (12V RAD)
blue
ANT (antenna amplifier)
orange
FL+
pink
FL-
violet
FR+
light green
FR-
blue
RL+
brown
RL-
yellow
RR+
red
RR-
white
*note 1*
the ground is located behind the instrument/gauge panel
*note 2*
the tweeters are wired into the front speakers
*note 3*
+B to ground is always 12V
*note 4*
12V from ACC to ground when key is at ACC or ON position
wire color
GR (ground)
brown
ACC (ignition ACC)
gray
B+ (12V RAD)
blue
orange
FL+
pink
FL-
violet
FR+
light green
FR-
blue
RL+
brown
RL-
yellow
RR+
red
RR-
white
*note 1*
*note 2*
*note 3*
*note 4*
here is a tech article with all the wire info you need
https://www.scionlife.com/forums/viewtopic.php?t=42276
and for doing the radio install...
https://www.scionlife.com/forums/viewtopic.php?t=27719
lunchbx05
Dec 11, 2014 06:13 PM
ScionLife Editor
Dec 6, 2014 11:58 PM
sci-bionic
19
Dec 11, 2003 03:35 AM
