Help with speaker wiring
I am getting ready to put component speakers in the front with the tweeters in the dash. Where are the dash speakers wired from? Do the wires go to the doors then the dash or the dash then the doors? Any help is appreciated.
Thanks
Sean
Thanks
Sean
I can't answer your question but I would suggest running all new wiring for your components and leave the factory wiring alone.
There are 2 benefits to running fresh wires: 1. it's super easy to put the factory stuff back in when you sell or trade the car, 2. the factory speakers don't use a separate crossover like your components do so you'd have cut the factory wiring all up to make it work anyway.
I have the adapters that plug into the factory plugs in the doors. I was going to run cable to xover in the dash and then use the factory wiring behind the radio to run to the door and then I guess I will just wire a new wire to the top of the dash.
clickclickw00t
Feb 18, 2015 08:57 PM
