hi to low converter
what you REALLY need is the converter made by NORCALSCIONS
http://cgi.ebay.com/ebaymotors/SCION...spagenameZWDVW
That ebay deal isn't bad at all. This is what I ran on the install in my wife's xB...
http://www.edesignaudio.com/edv2/pro...roducts_id=174
It probably would have been worth the difference in cost to get the kit off of ebay. Getting the type of splices I wanted was the biggest hassle. With the ebay kit you don't have to deal with that. I also spliced the LOC in right after the stock head unit. It is all hidden up in the dash.
I would highly recommend getting one of these to go along with the install if you are only adding a subwoofer. http://www.sonicelectronix.com/item_3792.html You just plug it into your RCAs in line between the head unit and the amp. Tune your amp with the Bass Control turned all the way up. Then if you ever need to reduce your bass it is as easy as turning the little ****. A great investment for only $13.
the best loc is the PAC,here is one
http://cgi.ebay.com/PAC-OEM-2-OEM2-4...QQcmdZViewItem
yes you can run 2 amps with this
Originally Posted by Forklift
Id rather pull the radio to get the LOC location and be able to tap the remote there too
if you mean pull the radio out to put the LOC in the back of the HU, yeah, that's definitely required
well, the one on ebay was plug and play, and specifically built for our cars... I had purchased two others, in addition to a scoche TAO2, and realized I'd be so much better off with the one from ebay
it's up to you, I'd buy his 'full enchilada' one, but that's just me. I had a great experience with that seller/product, and it continues to perform well.
mischman
Sep 15, 2015 03:38 PM
Ismvelas2
Aug 17, 2015 02:22 PM
