High-Level converter question
Old May 17, 2005 | 05:58 PM
Sean05tC's Avatar
Default High-Level converter question
Im gonna be installing my headunit today. When i had my system connected to the stock radio I used a high-level converter for the RCAs. The headunit I have now has sub RCA outs, so I wont be needing the converter, but it will still be spliced into my rear leads. Retarded circuit city cut the brown ground wire pretty short, and I heard that if you dont have RCAs connected to the converter, that it needs to be grounded? Is this true?
Thanks.
Old May 17, 2005 | 06:11 PM
SCI_TC_GUY's Avatar
best thing to do would be to remove the converter completely and butt-connect or solder the speaker leads back together.....
This is precisely the reason I don't allow best buy or circut city to touch my car.......
Old May 17, 2005 | 06:13 PM
Sean05tC's Avatar
yeah, the second installer i had look at it, asked me three times who installed me previous unit, because apparently the guy broke 2 or three rules or guidelines for roadshop installs. Never going back, ah well I guess thats another 30 minutes out the window today.
Thanks.
Old May 17, 2005 | 07:04 PM
Sean05tC's Avatar
Hmmm, say i didnt want to do that LOL. can I just ground it and be ok? or will it work ungrounded since the speaker leads basically pass through it
Old May 17, 2005 | 08:03 PM
SCI_TC_GUY's Avatar
I don't have much experience with bottom of the line converters cause they sound like crap..... I would say that you would be ok to not ground it at all.....why don't you want to remove it though????
Old May 18, 2005 | 03:39 AM
Sean05tC's Avatar
I dont want to screw the factory wiring up anymore than circuit city already did. Can ya blame me?
Old May 18, 2005 | 03:42 AM
Sciond's Avatar
go get a PAC line out converter if you need to use one
Old May 18, 2005 | 04:08 AM
mike51392's Avatar
i had to install a high-level converter for the RCA for my amp i solder all the wires and used shrink tubing i did a really nice job i completly removed the brown wire from the converter - u should just cut the converter off its just 4 wires
Old May 18, 2005 | 11:12 AM
SCI_TC_GUY's Avatar
I highly doubt you could screw it up more than circut city, I'd highly highly highly recommend removing the converter.....take your time and use some logic and you'll be fine.....
Old May 18, 2005 | 06:10 PM
Sean05tC's Avatar
Sounds good, Ill do that then, thanks much.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
xBassist
9
Jan 21, 2004 07:34 PM
