How do i bridge a 4 channel amp *PICs*
I want to know how do i bridge a 500 watt amp with two 10 inch subs so i could get the full power of the amp to the sub. I got pics. can anyone show me by editing the pics by showing me how to bridge it? i got a phoenix gold amp heres the specs:
Phoenix Gold Octane R Series 500 Watt 4 Channel Amp
Class A/B Output Stages
Audiophile Grade Components
Continuous Power Output @ 4 Ohms Stereo: 50 Watts(rms) x 4
Continuous Power Output @ 2 Ohms Stereo: 75 Watts(rms) x 4
Continuous Power Output @ 4 Ohms Bridged: 150 Watts(rms) x 2
Maximum Power Output @ 4 Ohms Stereo: 80 Watts(peak) x 4
Maximum Power Output @ 2 Ohms Stereo: 125 Watts(peak) x 4
Maximum Power Output @ 4 Ohms Bridged: 250 Watts(peak) x 2 <<---- this is what I'm trying to to do. can any one help me?
In Stereo Mode Stable To 2 Ohms
In Bridged Mode Stable To 4 Ohms
Built In Electronic Crossover
12 dB/Octave Crossovers
User Selectable High/Low Pass
Crossover Continuously Variable From 40 Hz To 400 Hz
Built In Bass Boost Circuitry
Variable Bass Boost Level From 0 To +15 dB
Bass Boost Center Frequency @ 45 Hz
Pass Thru Pre Amp Outputs
Frequecy Response From 20 Hz To 20 KHz
Signal To Noise Ratio Greater Than 110 dB
Accepts Up To 4 Volts(rms) Pre Amp Level Inputs
RMD Port (For USe With Remote Diagnostic Diplay: Optional)
Approx Exterior Dimensions: 11"x2.25"x13.75"
[/img]
[/img]
What you need to do is look below the speaker connections and it show which two terminals to use to bridge, this will be the same for both sets. Make sure you switch the input switch to front only os it will use the same signal for both subs. To do this though your subs need to be single 4 ohm, dual 2 ohm (wired in series for 4 ohms), or dual 8 ohm (wired in parallel for 4 ohms). If you need further help e-mail me at GLN305@hotmail.com
Later,
Glenn
EDIT:
I just noticed that you have the sub currently hooked up to one bridged set of channels. Treat the bottom row of terminals and top row of terminals seperately. Basically, just remove one sub from the bottom row and move up to the top, observing polarity (+ and -).
Later,
Glenn
EDIT:
prescottn
Scion tC 2G ICE & Interior
Apr 26, 2016 01:14 AM
