How do you remove the Oven on an xB?
Old Oct 12, 2006 | 05:32 PM
ZanexGt's Avatar
Default How do you remove the Oven on an xB?
Hey all,
I am installing a Magellan Roadmate 300 in my '05 xB. The GPS is powered by means of a cigaretter lighter adapter. I will be taking off my center guage bezel on the top of my dash and routing the wires behind the dash towards the cigaretter lighter.
However, I want to remove the oven so that I can get to the cigarette lighter wires and solder in another cigaretter lighter adapter (behind the dash) so that I can use that plug to plug in my GPS. Therefore, the wires from the GPS would be hidden behind the dash, the new plug would also be behind the dash, and I'd still retain use of my factory cigaretter lighter.
Anyway, I need to remove the oven so that I can get to the wires. How do you remove it?
I saw some threads on removing the xA oven but found nothing on the xB when searching "oven" "oven removal" "dash removal", etc.
Thanks in advance for the help!
Old Oct 12, 2006 | 05:52 PM
kkawana's Avatar
think it just kinda 'pops' in/out.... dont think there is anything to unscrew
once you get the silver trim peice off (see tech section for stereo install or hvac light change) you should be able to remove it w/just a bit of effort
Old Oct 12, 2006 | 05:56 PM
ZanexGt's Avatar
Thanks. That was my initial thought but I figured I'd post here and ask before 'yanking'. With my luck, I'd end up breaking something!
hmm, any else removed their Oven?
Old Oct 12, 2006 | 06:22 PM
kkawana's Avatar
no prob... mine is gone actually.. but i wasnt present for its removal.. i cant tell you the hows or whats
Old Oct 12, 2006 | 06:37 PM
ZanexGt's Avatar
So I went out to the toaster and gave the oven a little tug and voila, it popped right out. I was surprised at how easy that was. I guess I was just paranoid that there'd be a fastner or something else in there keeping it in place.
So for anyone reading this thread, just pull on the oven with even pressure and it'll pop out.
Thanks for the help kkawana
Supertech's Avatar
Yep, that's it. Take the silver trim off and the oven has four of those wedgey push in clips like the silver trim piece has. very easy to remove.
Old Oct 12, 2006 | 08:04 PM
kkawana's Avatar
cool.. glad it worked
steeze69
May 24, 2021 02:57 AM
Sgtfluffy16
Sep 30, 2015 01:42 PM
jbernard
Sep 3, 2015 12:03 AM
StxArOne
Scion xA Aero & Exterior
Aug 29, 2015 03:29 PM
